Old 06-17-2022, 07:43 AM   #1
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Rear springs for Tarmac 2
Hi, I have the RCE Tarmac 2s (KW clubsports) and would like to stiffen the rear slightly. Currently has the 70-170 blue springs they came with. 400# or 7kg I think. What springs can I get and where?
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 06-17-2022, 09:00 AM   #2
Racecomp Engineering
Ahhh thanks for posting. I accidentally deleted your PM and when I realized it I couldn't remember your screen name. Apologies.
We do Swifts generally...60mm ID. Give us a call if you'd like to order or send us an email.
8 kg/mm is a common way to go in the rear if you're keeping the fronts at 7. Any stiffer than that in the rear and I'd recommend increasing front rates as well.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
bmacfrs (06-17-2022)
Old 06-17-2022, 12:31 PM   #3
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
- Andrew
Looking at the Swift size chart for 60mm I see either 6 inch or 7 inch length. The 70-170 originals are 6.7 inch. So do you recommend the longer ones? I have the car lower in rear only about an inch.
Old 06-17-2022, 01:53 PM   #4
7 inch
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
bmacfrs (06-18-2022), wparsons (06-27-2022)
Old 06-19-2022, 09:44 AM   #5
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Why not order the 80-170 spring kit from ST suspensions?
Tatsu333 is offline   Reply With Quote
Old 06-19-2022, 07:11 PM   #6
strat61caster
strat61caster's Avatar
Originally Posted by Tatsu333 View Post
That’s overpriced as fuck, op already has the tenders and intermediate collar.
A pair of eibach or hyperco springs with shipping should be <$150.
ineedyourdiddly
Old 06-22-2022, 02:53 PM   #7
Tatsu333
Meh - for me, I'd rather pay the difference to have the ST/KW springs and have them match (colour-wise) the original front springs, but I'm picky like that...LOL.
Old 07-13-2022, 09:26 PM   #8
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
So I found a set of Swift springs that are 60mm diameter, 8kg, and 178mm length (7inch). Looking at their part number sheet this is the only length they have in that diameter and rate. The originals on the shock is 170mm (6.67 inch). Installing these by simply replacing the spring and inculding the helper and spacer rings collapses the helper all the way. Its not crushed by theres no room left. Is this okay or do I HAVE to find 7 inch springs?
Old 07-13-2022, 09:29 PM   #9
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Here's what it looks like compared to original
Sent from my SM-S901U using Tapatalk
Old 07-13-2022, 09:59 PM   #10
That's totally fine like that. If you were to lower the car more the helpers would be uh, helpful to keep the main springs captive. But at your current height they're just taking up space, which is fine though you could remove them.
- Andrew
bmacfrs (07-14-2022)
Old 07-13-2022, 10:14 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine are like that too. It’s no big deal.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 07-14-2022, 10:01 PM   #12
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
- Andrew
How is this going to affect ride height with a stiffer and slightly longer spring? (although the helper is compressed more now so taking less space)
I assume I will need to readjust lower?
Old 07-18-2022, 08:58 AM   #13
Correct.
bmacfrs (07-20-2022)
FS: RCE Tarmac springs mpoynter Brakes, Suspension, Chassis 2 12-02-2017 07:34 AM
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 02:49 PM
FS: RCE Tarmac Springs trippinbillies40 Brakes, Suspension, Chassis 1 05-26-2017 06:40 PM
wtb: rce tarmac springs redlined600 Want-To-Buy Requests 0 04-09-2015 12:52 PM
RCE Springs from Tarmac Zero - 280# NEW jack43 Brakes, Suspension, Chassis 0 03-22-2014 02:41 PM
