Old 06-16-2022, 09:16 AM   #1
Averagebrz
Drives: Subaru brz
Car not idling and stalls when clutch is engaged….
Hey everyone I’ve encountered an issue today and I would like some advice on what is happening to my car. Today I changed the speakers in my doors, everything went smooth but when I reconnected my battery and took it for a drive it stalled very easy when I pushed my clutch in and ran pretty rough when trying to change gears. I’m suspecting it to be some sort of idling issues as it isn’t sitting at idle where it used to be before I unplugged my battery but a bit confused why the clutch would be doing this unless my throw out bearing magically failed while I was parked. Would appreciate any advice thanks !
Averagebrz is offline   Reply With Quote
Old 06-16-2022, 09:18 AM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Computer has to re-learn after battery disconnect. Just drive.
Old 06-16-2022, 01:16 PM   #3
radroach
Drives: car
@Averagebrz These cars have a sloppy throttle response after reconnecting the battery and have to do the throttle re-learn.
clutch failure, idle, throw out bearing
FRS Rattle when clutch engaged in neutral savioita Issues | Warranty | Recalls / TSB 20 11-26-2017 04:00 AM
Automatic FR-S randomly stalls when Idling LzT AngeL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 12-15-2014 08:31 AM
Car sensing clutch fully engaged when its not// 504 Issues | Warranty | Recalls / TSB 1 09-16-2014 10:02 AM
Car almost stalls but clutch is all the way in when stopped LaertesSon Engine, Exhaust, Transmission 11 05-13-2014 05:55 PM
Display current gear without clutch engaged? cfusionpm Scion FR-S / Toyota 86 GT86 General Forum 45 03-26-2013 04:08 PM
