Drives: 2013 Manual Trans FR-S
Broken wire on side marker pig tail
Hi all.
I broke the black wire on the pig tail that plugs into the hockey stick shaped socket that the side marker goes into. What's the best way to fix this? Is |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Cut tape keeping the protective loom closed, remove the wire terminal from the connector, obtain a replacement with weather seal, crimp it on a new length of wire, cut the car's original wire back a bit, install new wire/terminal and splice in-line, heat shrink, tape up and re-loom the wiring, insert terminal into connector body until it locks.
Drives: 2013 frs base
OP asked for the best way to fix this, not the worse. His wire is broken near the terminal at the base of the long plastic socket, what he needs to do is repair the wire, not chop off everything and install a universal socket that will fit badly.
That's not what's broken. I broke the wire that goes into that socket.
#7 | |
ProCrastinationConsultant
the easy/standard fix is to replace the socket. if one was in desperate need to retain the original oem socket for nostalgia and hotrod originality street cred, it would require a depinning tool, a crimper, and a replacement crimp. the depinning tool and crimper alone are going to run about $50, about twice the cost of the replacement socket.
#8 | |
That's what I do, except instead of going to a pick-and-pull, anytime we've got a wire harness to throw away, we don't. We've got a huge pile of wire harnesses in the attic and anytime I've got to repair a wire that's broken too close to the connector, I got up, grab something similar and repair. The only other alternative presented in this thread is a universal 194 socket which won't fit. |
| Carbon Side Markers - The Fix to the Falling Out Side Marker | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 12-20-2019 02:47 AM |
| How exactly does the front side marker wire connect ? | GrantedTaken | BRZ First-Gen (2012+) — General Topics | 3 | 02-14-2018 12:24 PM |
| Back Up Camera - Reverse Wire broken what to do?? | Mikeez | Electronics | Audio | NAV | Infotainment | 16 | 11-23-2015 11:56 PM |
| Where to buy side marker wire and bulb? | Landon096 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 06-29-2015 12:39 PM |
| FS: Oem head & tail lights, break light & side marker | Vesalera | Exterior Parts (Aero, Lighting, Etc.) | 6 | 04-17-2015 11:52 AM |
