Drives: Black Scion FR-S
Techron full system cleaner made my car crank but no start
So I used Techron full system cleaner on my car, was able to drive from gas station almost to my house (legit a street from my house) before car started “giving out” as it started pulling back and didn’t want to go , would get stuck at around 2.5k rpm’s. Pulled over and then my engine died , I was able to turn it on right away, take it home and I left it overnight, the next morning tried turning it on and it’ll just cranks. Now I got two error codes one was fuel and air ratio code and the other was a multiple misfires. I’ve checked the fuze boxes, everything good they have current and none look bad, I’ took the maf sensor off to look at it , and it looked good and clean, the throttle body was a bit dirty so I cleaned it, still only cranks. The only thing I can think of it being is the Techron cleaned all the gunk and shit I had in the gas tank and my fuel filter collected it and got clogged up. I’m trying to measure the pressure of the fuel with a gauge but for some reason our cars don’t have a valve to plug the gauge in for a reading, I was told to plug in directly to a fuel line ? And also how should I go to changing the fuel filter if my gas tank is full, better off having a mechanic do it ? Also this car has 105,000 miles on it I believe you gotta change the fuel filters at 75k miles and I’m sure the old owner never did that which is another reason I think the fuel filter is clogged but wanna run tests to pinpoint if it really has to do with the fuel pump
Drives: 2023 Toyota GR 86 Cup
Bad gas is more likely....
2023 GR Cup Car
not playing cards
Used Techron complete system cleaner and car is limp mode
You should check with this guy's mechanic.
| Used Techron complete system cleaner and car is limp mode | Limitz | Issues | Warranty | Recalls / TSB | 21 | 06-13-2022 03:06 PM |
| Engine Flush and Fuel system cleaner. Use or not to use | 1234eher | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 08-18-2020 07:54 PM |
| Crickets be gone! lucas oil deep clean fuel system cleaner | SliverBrz | Issues | Warranty | Recalls / TSB | 15 | 09-23-2013 08:22 PM |
| Save BIG on Sonax Full Effect Wheel Cleaner DetailersDomain.com | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 09-19-2013 10:06 AM |
| Here's your shot to WIN A LOT of Sonax Full Effect Wheel Cleaner | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 01-18-2013 07:15 PM |
