Old 06-08-2022, 09:48 PM   #1
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
Tein Flex Z Settings
Just purchased a set of Tein Flex Z, and looking through the manual and comparing the current measurements to what they say they should be... but are the measurements in the manual given for stock ride height?
It gives reference values of -
Front: 24mm gap between top ring and bottom ring
Rear: 38mm gap between top ring and bottom ring
I know I will have to make at least one adjustment once I get it on the ground after installation, but I was just wondering if those numbers reflect a stock ride height or not. I am looking for a 20mm drop.
Regarding dampening, I have heard that 5 clicks from hardest is decent for daily driving, but for AutoX I assume I would want to put them on the stiffest possible?
Any other suggestions from current owners?
Current: 2013 Scion FRS - Whiteout
knapper is offline   Reply With Quote
Old 06-09-2022, 11:17 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Before you chuck 'em on, just make sure to measure from the center of your wheel hub to the fender so you'll have before measurements so when you make adjustments to the height, you know how much you're changing it.
I read the five clicks out also and have been using that on my daily and it's been nice.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
knapper (06-09-2022)
Old 06-10-2022, 09:36 PM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I did 1.2 inch and almost perfect
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
knapper (06-12-2022)
Tein Mono Sport Suspension settings for Street / Track nova.86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 11-05-2021 05:03 AM
Tein Flex A/ Flex Z Durability jc7993 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-03-2020 09:35 PM
Tein flex a or flex z coilovers? Phuviano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-17-2019 04:37 PM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
