Old 06-07-2022, 10:40 AM   #1
SpeBud07
Drives: 2013 FRS
When do you need adjustable toe links?
I've got new RCE SS-1's sitting in a box with TWS T-66F (18x9.5) shod in 255/35/18's ready to go with them on our 2013 FR-S Build.
I've decided to get adjustable LCA's and am leaning toward a basic SPC set up. If I needed to lose weight there, I can upgrade later, but the driver probably needs to lose more weight than the car at the moment lol.
What about Toe Arms though? When I drop the car 1"-ish with this install, will I likely need to address rear toe?
SpeBud07 is offline   Reply With Quote
Old 06-07-2022, 10:53 AM   #2
Tatsu333
Drives: 2020 BRZ Sport Tech RS
With that mild drop, the stock toe arms will be fine to get you the adjustment needed.
Tatsu333 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tatsu333 For This Useful Post:
SpeBud07 (06-07-2022), strat61caster (06-07-2022)
Old 06-07-2022, 11:07 AM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I got the MOOG greaseable toe links with an SPL eccentric lock out. My reasoning was rubber bushing like stock, adjustable, greaseable and lockout will keep toe from possibly slipping.
dragoontwo is offline   Reply With Quote
Old 06-07-2022, 12:15 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As long as you don't run a bunch of rear camber and reasonable ride height stock will be fine. The toe link attaches to the front of the rear hub, so more negative camber tilting the top of the tire in, toes the rear tires out. I am at like -2.5-2.6 in the rear. I had RacerX toe links and couldn't get them short enough at -1.5" ride height.
Old 06-07-2022, 12:27 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
You probably don't need adjustable LCAs or toe links. I'm lowered 1.25" and no probs with getting rear toe-in set to the ~0 to 0.1 degrees total I like with the factory toe links. And I'm at -2.5/-2.7 rear camber, pretty much right where I want it for street/track. Even for street-only, this is not excessive or problematic as long as toe is kept minimal...
Old 06-07-2022, 01:19 PM   #6
marco_mc22
Drives: Toyota 86
1) Not enough adjustment range
2) Get rid of eccentric adjustment + sloppy stock rubber bushings
I use hardrace pillow ball (sealed ones) links and I love them, easy to adjust when you perform string alignment, sealed pillow balls for durability and using custom eccentric lock shims has finally made rear toe durable, stock eccentric arms slip very easily especially if not torqued properly and car is a bit abused.
As other said you don’t need them but they’re a good upgrade in my opinion, even with rubber bushings.
marco_mc22 is offline   Reply With Quote
Old 06-07-2022, 03:28 PM   #7
SpeBud07
Drives: 2013 FRS
Thanks, I've had other discussions that said that too, which is my preference. I'm not really wanting to give up my factory bushings for sphericals just yet. I'm too old not to value my kidneys. If the race bug hits me again, I'll go that way for sure.
Whiteline adjustable end links (FL) 8RZ Brakes, Suspension, Chassis 3 05-09-2017 10:22 AM
Adjustable end links bored@work84 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-30-2017 07:07 PM
Adjustable sway bar end links Dori_86 Want-To-Buy Requests 1 10-16-2016 02:07 PM
Adjustable End Links (Rear) digital_assassin Brakes, Suspension, Chassis 2 09-26-2015 04:43 PM
Adjustable End Links $30 shipped SlowCone Brakes, Suspension, Chassis 0 04-25-2015 05:11 PM
