Drives: 2013 Brz
Need some help with my abs system
Hello all I'm having an issue with my 2013 brz I've done the 17+ abs module cluster and pp brake swap. After I did the brake swap I have a spongy pedal I've been trying to use techstream to bleed the abs as well as my friends snap on scanner but nether will connect to the abs module and I'm not sure what could be happening any advice would be greatly welcomed
Drives: Scion FR-S 10 Series
If you do not mind getting the car dirty, the old way of bleeding the abs would be to got to a dirt or othe low traction surface and repeatedly activate the abs system while driving. Hope this helps.
| Borla "full system" VS "full system" minus headers | Trashed675 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 01-07-2014 12:17 AM |
| Be Spoke system/ BRZ system navigation swap | Mrqb22 | Electronics | Audio | NAV | Infotainment | 4 | 09-27-2012 05:48 PM |
