Old 05-23-2022, 08:36 AM   #1
UNCC_BRZ
UNCC_BRZ's Avatar
Drives: 2013 WRB BRZ Limited
Clicking / Popping noise from steering when not moving or low speed
https://drive.google.com/file/d/1SCu...ew?usp=sharing
Video with good sound example of noise. Video was made without the car moving, but similar sound at low speed. Primarily from the front drivers side.
Like the title says, I am getting this clicking / popping noise when I turn at a standstill / low speeds. It seems to only start making the noise once I turn the steering wheel past the 4/8 o' clock position, so it might also do it at high speed, but I dont turn the wheel past that when driving at high speed too often, and my exhaust is too loud to be able to hear it at higher speeds anyways.
2013 BRZ
100k miles
Still on original factory suspension. Only suspension part that has been replaced is rear drivers side strut around 60k miles.
I realize that a lot of the suspension parts might be going bad with this many miles, but it still rides and handles great. Only started making this noise about two weeks ago? I only drive the car 2-3 days a week. Less than 500 miles a month for the past 2 years.
25mm spacers in front
30mm spacers in back
Spacers have been on the car for less than a year, and only about 4-5k miles.
I am sure that a suspension bushing is the culprit, I'm just not sure which one it might be?
2013 WRB BRZ
Gruppe-S headers|| Borla Cat back||OFT Stage 2+
UNCC_BRZ is offline   Reply With Quote
Old 05-23-2022, 09:19 PM   #2
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
My 2017 had a bad bearing on the top right strut. It took two people to locate the noise. While an assistant turned the steering lock to lock, I felt the vibration with my fingers. I first thought it was creaking bushings on the sway bar. Check the top of the struts. Apparently it is a problem that affects lots of car makes.
The ants are our friends, they’re blowing in the wind, that ants are blowing in the wind.
Flarpswitch is offline   Reply With Quote
Old 05-23-2022, 11:32 PM   #3
norcalpb
norcalpb's Avatar
Sounds like front top hats to me. If the bearing stops spinning freely, the top half of your spring wont rotate with the lower half of your spring, causing it to slip and make a boing noise.
The lower spring perch is moved by the tie rods but the upper perch is kinda just along for the ride.
Old 05-26-2022, 10:31 PM   #4
ermax
ermax's Avatar
It’s probably a disintegrated EPS coupler. It’s a $7 fix. I’ve got a DIY, let me dig it up.
Here:
https://www.ft86club.com/forums/showthread.php?t=133606
The Following User Says Thank You to ermax For This Useful Post:
soundman98 (05-26-2022)
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Clicking/popping noise form coilover? thecarfilmer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-13-2016 09:51 PM
Clicking noise in steering column Shimmyshake Issues | Warranty | Recalls / TSB 3 08-16-2016 10:13 PM
Question about warranty work and steering clicking at low speed JM197 Issues | Warranty | Recalls / TSB 5 07-20-2016 10:55 AM
