Old 05-18-2022, 04:40 PM   #1
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
Fallen RT 660 fitment
I’m running RT660 245/40 17 on a 9 wide 6ul and I’m getting a pretty good rub on the front wheel well that I did not get with the yokes. Also what tire pressure is working for everyone. I know it set up and course sensitive. I believe I have between 3 and 3 1/2 negative camber up front. I have less rub after I removed the camber and crash bolts from the front. On a low speed 49 second course , I found I had the best turn in at 25 psi up front with good rear grip at 27/28. 25 sounds too low and I don’t want t destroy my tires. Grassroots Motorsport tested them on a ND Miata and found 28psi was best. What is everyone else’s experience.
Autoenthusiastasm is offline   Reply With Quote
Old 05-18-2022, 04:44 PM   #2
Code Monkey
Drives: Subaru BRZ
You need at least 7mm spacers in front.
Code Monkey is offline   Reply With Quote
Old 05-18-2022, 05:03 PM   #3
jflogerzi
jflogerzi's Avatar
What offset for the wheels?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
timurrrr (05-23-2022)
Old 05-18-2022, 05:05 PM   #4
Code Monkey
Drives: Subaru BRZ
17x9 6UL so +40.
Old 05-18-2022, 05:26 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Maybe try offset top mounts for more camber? Wouldn't go bigger than 3mm spacers if using stock length studs.
For pressure, I aim for ~35psi hot at the track. Or ~26psi front 28psi rear stone cold. In my experience most 200tw radials are fairly pressure insensitive within reason...
Danny318 (06-09-2022)
Old 05-18-2022, 05:52 PM   #6
Autoenthusiastasm
If I used a spacer, I would upgrade and lengthen my studs. ARP
Old 05-18-2022, 06:01 PM   #7
Where in the wheel well are you rubbing?
Lynxis (05-18-2022)
Old 05-18-2022, 06:14 PM   #8
Code Monkey
Drives: Subaru BRZ
My guess is the usual suspects.
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
CSG Mike (05-18-2022), Jdmjunkie (05-18-2022)
Old 05-18-2022, 06:42 PM   #9
jflogerzi
jflogerzi's Avatar
Camber from the top hats is what you want. Camber from bolts bring you closer to the suspension. What's your ride height?
Old 05-18-2022, 07:56 PM   #10
dreamwonder
Drives: GR86 2022
With +40 offset, Versus Steering Rack Limiter Kit will solve the rubbing. 1 spacer on each side is enough.
dreamwonder is offline   Reply With Quote
The Following User Says Thank You to dreamwonder For This Useful Post:
Code Monkey (05-19-2022)
Old 05-19-2022, 07:35 AM   #11
Autoenthusiastasm
Before removal of the camber bolts, top of the wheel wells under heavy braking, After removal. I’ll post picture of of the rub. Forward of the coil over . Ride height is not crazy low. I have a 1 1/2 l gap wheel well. I’ll measure. Sorry on the way out to work.
Old 05-19-2022, 08:30 AM   #12
Autoxer62
I'm running 28 psi square, that was faster than 30 and was also good based on surface temps and apparent tire patch contact. I tried 26 but it didn't really feel better to me and wasn't faster, at least when it's at least 70 outside. I didn't think to try something lower the first couple events this year, given where you live that may be a factor. Gonna be plenty warm this weekend, tho.
I do get a little rubbing at the front of the wheelwell, but nothing too bad, however I have +35 wheels.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 05-19-2022, 09:10 AM   #13
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
I currently have 255/40R17 660's on +40 6ULs. -3.8 camber up front.
I only rub on inside fender well at full lock. Not sure why you would be rubbing while braking.
I run same pressure setup as my Yoks, pyro'd the tire (autocross use) and everything looks good.
Cold: 27F, 26R
Hot: 28-29F, 27-28R
Breezio is offline   Reply With Quote
Old 05-19-2022, 10:22 AM   #14
deca
Drives: Halo 860
I recently ran a session on 255 660s and had no noticeable rub. I'll be monitoring it as I spend more time on them though.
17x9 +35 with 4 degrees of camber.
deca is offline   Reply With Quote
Has any FRS/BRZ fallen to LS V8 engine swap? suzuka Engine Swaps 216 09-15-2016 03:15 PM
I've fallen and I can't get up dvasqu01 Off-Topic Lounge [WARNING: NO POLITICS] 19 02-15-2016 12:39 PM
I've fallen for my FR-S.. Cyrious G FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 01-09-2013 04:47 PM
New Zealand Sends off A Fallen Soldier travace Off-Topic Lounge [WARNING: NO POLITICS] 3 09-05-2012 12:30 AM
Have you fallen in love with this car? Bristecom Scion FR-S / Toyota 86 GT86 General Forum 26 05-25-2012 06:39 PM
