Old 05-10-2022, 08:26 PM   #1
Nick.brz
Drives: 2013 Subaru BRZ
(Very Important) Brz Valve Spring Recall Information
I know there is probably a thread out there with this information but I am new to the forum and I need answers
Back in December my timing belt went
When I took my car to the dealer they fixed the timing belt and also preformed a valve spring recall
couple weeks later I started leaking oil so I took the car to the dealer and they resealed the engine free of charge
couple weeks after that I was still leaking oil so I once a again, took my car to the dealer where they resealed the engine free of charge
My car has been running fine up until a week a go when my car started to feel slower. Fast forward to last weekend I was driving on the highway and my car started sounding like a helicopter so I pulled over and got my car towed to the dealership.
They called me today saying I have and cylinder 3 misfire and a rod knock and quoted me 15k for a new engine.
I don't have much knowledge on engines but is it possible that the first two times I took my car to the dealer they did not use enough sealant (which caused the oil leaks) and the second time they applied too much sealant which caused the missfire and the rod knock?
If anyone can give me more information I would greatly appreciate it, going to meet with the manager tomorrow hopping they will take the blame.
Nick.brz is offline   Reply With Quote
Old 05-10-2022, 09:14 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That’s exactly what happened. There is a whole thread on J02 recall failures.
Old 05-10-2022, 09:33 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
also important to note, these vehicles have a timing chain, not a timing belt. timing chains do not need to be replaced.
Teseo (05-12-2022)
Old 05-10-2022, 09:58 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Welcome to the j02 club. We should make t shirts
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following User Says Thank You to DarkPira7e For This Useful Post:
Ultramaroon (05-10-2022)
Old 05-11-2022, 12:31 AM   #5
Gutterboy
Drives: 2013 frs; 1988 porsche 944s - > 948
very sad news to hear, haven't heard much more buzz on this but i have a 2012 and i'll be damned if i let anyone touch mine for this heinous recall.
been running boost for over 5 years and no issue so i see no reason to do anything on my end. here's hoping and i do hope you find a resolve that doesn't stick you with the entire bill.
Gutterboy is offline   Reply With Quote
Old 05-11-2022, 08:15 AM   #6
Lawyer up. They screwed up the sealing and caused a blockage in the oil passages. This failure is on them but they will fight it every step of the way.
https://www.ft86club.com/forums/showthread.php?t=133095
https://www.ft86club.com/forums/showthread.php?t=133306
Capt Spaulding (05-11-2022), Teseo (05-12-2022)
Old 05-11-2022, 09:56 AM   #7
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
Sad reading, my car went through valve recall fix-> New bottom end a year before i bought it. I just wish Toyota would have made the engine instead..
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
Old 05-11-2022, 09:59 AM   #8
Nothing to do with who made the engine. The other cars in the recall that didn't have the FA 20 didn't suffer the same fate.
Who knows it could have been worse if it was a one off Toyota engine just as it is a one off Subaru one.
Teseo (05-12-2022)
Old 05-11-2022, 11:33 AM   #9
Nick.brz
you are right, it was not my timing belt, it was the serpentine belt. from what I remember one of the pulleys was not working properly and it burnt a hole through the belt
The Following User Says Thank You to Nick.brz For This Useful Post:
soundman98 (05-11-2022)
Old 05-11-2022, 11:34 AM   #10
Nick.brz
To my understanding, this has nothing to do with the engine, this was caused by Subaru technicians not doing their job right.
Old 05-11-2022, 11:36 AM   #11
Nick.brz
I spoke with the manager and he said he is seeing what they can do... almost like he knows they fu**ed up and trying to cover their tracks.
Old 05-11-2022, 11:38 AM   #12
Nick.brz
Im a 18 yr in high school, a lawyer isn't really something I can afford so I'm hopping we can resolve this without one.
Old 05-11-2022, 11:49 AM   #13
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Maybe apply leverage through SOA?
dragoontwo is offline   Reply With Quote
Old 05-11-2022, 11:52 AM   #14
You may be able to. There were many dealers that did indeed acknowledge that they screwed up and ate the cost of the repair. The fact that they quoted you a replacement price is not a good indicator that they will do this though I am afraid. Before you agree to paying any repairs check around for a lawyer that will at least talk to you. Many will not charge for the first consultation. Will give you a better idea of your chances in a fight and could be way cheaper than the $15K replacement cost.
Did you authorize them to do the recall work or did they just do it on their own?
Busybee (06-11-2022), soundman98 (05-11-2022)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 05:24 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 08:44 PM
