Old 05-10-2022, 06:55 PM   #1
tobin
tobin's Avatar
Drives: '13 BRZ
JDM armrest hinge keeps popping out?
Hello - I just bought a brand new Toyota armrest to replace my 8 year old broken one. Installation was a breeze since the holes were already drilled for the old armrest. I have noticed over the past few weeks that every time I open the arm rest, the rear "hinge" pops out of its guide slot. Am I missing a part? Is there something that is supposed to keep the rear hinge captive like the front hinge? I can push it back in place while I close it, but it pops out every single time I open it. The mounting hardware is barely snug, so I don't believe it's warped or anything.
tobin is offline   Reply With Quote
Old 05-10-2022, 09:35 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i thought there were some screws that went through that? could be wrong though
tobin (05-11-2022)
Old 05-11-2022, 02:59 AM   #3
RapidEntropy
RapidEntropy's Avatar
Drives: 2013 GT86 Limited
Mine did the same thing twice. Had to disassemble it the first time because the pin in the hinge got loose. The second time the hinge itself broke.
Love the armrest but the hinge seems pretty shitty. I don't have any pressure on the structure of the armrest either.
RapidEntropy is offline   Reply With Quote
The Following User Says Thank You to RapidEntropy For This Useful Post:
tobin (05-11-2022)
Old 05-11-2022, 04:29 AM   #4
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
There's supposed to be some metal studs that poke out from the plastic part that hinges the two pieces together on both ends, they may have been retracted into the plastic itself.
I had this happened to me before... The solution is to take those circular covers off and undo the torq screws and push the studs back out. I then used CRAZY Glue to glue them back in place so they will NEVER retract again.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following 5 Users Say Thank You to DaJo For This Useful Post:
Nails (05-11-2022), soundman98 (05-11-2022), Tcoat (05-11-2022), tobin (05-11-2022), wolffbite (05-11-2022)
Old 05-11-2022, 06:21 AM   #5
tobin
tobin's Avatar
Drives: '13 BRZ
Thank you so much! I opened the top and found the loose stud unattached to anything. I put it back in place and added a few drops of super glue to keep it in place (added a few drops to the front stud too). Great solution. Thank you for your reply!
The Following 5 Users Say Thank You to tobin For This Useful Post:
AJ32162 (05-11-2022), soundman98 (05-11-2022), Tcoat (05-11-2022), wolffbite (05-11-2022), x808drifter (05-11-2022)
Old 05-11-2022, 06:13 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
Glad it worked out! Mine is still going strong too.
2000 MR-S 5MT
2010-2012
The Following 2 Users Say Thank You to DaJo For This Useful Post:
soundman98 (05-11-2022), tobin (05-11-2022)
Old 05-11-2022, 07:26 PM   #7
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Ha! I had the exact same issues when I first installed mine.
Pin was loose, but mine was actually caused by the plastic sleeve around it cracking. I ended up using a liberal amount of JB Weld plastic bonder from the inside to repair it. The other side was fine, but I added the plastic bonder there to beef it up just in case. Been solid ever since.
wolffbite is offline   Reply With Quote
The Following 2 Users Say Thank You to wolffbite For This Useful Post:
Old 05-11-2022, 07:33 PM   #8
DaJo
FT86Club Vancouver
DaJo's Avatar
Yeah, they're quite finicky especially when not installed flush. If it's warped in any way the hinges don't like it and the plastics around the hinges gets put under a lot of pressure resulting in cracking. I had that issue as well. Like you, JB Weld did it's job and never had any issues since.
2000 MR-S 5MT
2010-2012
The Following User Says Thank You to DaJo For This Useful Post:
tobin (05-13-2022)
Old 05-13-2022, 03:32 PM   #9
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Looks like its a common issue with this armrest.
A bit of glue helps secure things.
Had same problem and sorted out like everyone mentioned above.
Thefalls is offline   Reply With Quote
The Following 2 Users Say Thank You to Thefalls For This Useful Post:
soundman98 (05-13-2022), tobin (05-13-2022)
Door Hinge and Bolt Covers jelder9 Interior Parts (Incl. Lighting) 2 01-08-2022 03:36 PM
GCS Black Door Hinge Covers - NEW - 2013+ FR-S / BRZ / 86 burgeralert Exterior Parts (Aero, Lighting, Etc.) 9 01-05-2021 11:13 PM
DWL Front splitter fastener / hinge - replacement part? 1Cor10:23 Tracking / Autocross / HPDE / Drifting 0 07-04-2016 12:28 PM
WTB: OEM armrest or Sutty's custom armrest J.C. Want-To-Buy Requests 0 10-20-2014 06:07 PM
Ideal armrest hinge TIE Pilot Cosmetic Modification (Interior/Exterior/Lighting) 4 02-24-2013 12:44 PM
