| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: '22 BRZ Limited 6MT - Ignition Red
2022 Subaru BRZ Top Speed Run 140mph on private road
Not bad for an NA 4 banger. Car felt rock solid at 140mph. Great chassis that can clearly handle more power and speed. Loving this car!
| The Following 2 Users Say Thank You to quikag For This Useful Post: | Code Monkey (05-06-2022), Lantanafrs2 (05-10-2022) |
Drives: 22 BRZ limited
Solid? At what speed did the lightness in steering go away at?
Drives: 2023 BRZ Limited
"Private road"...."Hazard reported ahead".....hmmmmm lol
| The Following User Says Thank You to Up4speed For This Useful Post: | OkieSnuffBox (05-10-2022) |
You should calibrate to GPS. There are some pretty decent apps for this, but generally indicated is lower than reality. My 05 STi was horrible, off by over 10mpg at 150 at a half mile event :/
Even so, 1-5 gears seem to pull pretty consistently. 6th gear acceleration is definitely noticeable slower. Was more of an RPM drop than I would have expected at that speed. |
| The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
Drives: 22 BRZ
I've been impressed by how planted the car feels at high speeds. It's really nice.
| The Following User Says Thank You to AK2112 For This Useful Post: | quikag (05-07-2022) |
#6 | |
This car feels surprisingly solid at triple digit speeds. I’ve owned many high performance cars (991.2 GT3, 981 GT4, current C6 ZR1, current CT5V Blackwing, etc.) and this car feels good, especially considering the price point. |
#7 | |
Nope, unless you are turning or the suspension is crap and you get significant float. Even still, my point still stands. This car, for $30k, has surprisingly good stability at high speeds. Suspension compliance, chassis rigidity, and precise steering give it the feel of a more expensive and sophisticated car. I'm surprised how effortlessly it will go down the road at 110-130mph (obviously engine is spinning, but it seems happy too).
Drives: '23 BRZ Limited
Quoting because me thinks OP is full of shit.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#10 | |
The US doesn't have specific regs on speedometer speeds but most European countries require the speedometer to NOT read low, but it can be off by as much as 10% on the high side (it says you are going 66kph but you are doing 60kph). Every car I've tested with GPS always read high by a varying degree. Never seen one with correct tires read low. Then I again I don't commonly drive my cars at 150MPH either.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 05-10-2022 at 01:18 PM. |
#11 | |
#12 | |
Tesla is a bit of an exception for this as they use all available data to indicate the speed, which usually makes them dead on.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#13 | |
I would see a pretty decent change from summer to snows, even though they were the same size. I would imagine you'd get a couple-few MPH off with brand new tires vs bald ones. The math says they'd read different. In most of the Subies I've owned, doing what you think is 80, is really 75-78. So scaling that up, it made perfect sense why my speedo was indicating 160mph, but the timing gate showed 150mph. |
#14 |
I realize now we are both saying the same thing (speedometer is typical lower than actual speed), somehow I managed to read your statement backwards....
| The Following User Says Thank You to Dadhawk For This Useful Post: | Dzmitry (05-10-2022) |
| 2022 Subaru BRZ on the Dyno | thekevinvo | BRZ Second-Gen (2022+) — General Topics | 41 | 02-08-2022 05:54 PM |
| 2022 Subaru BRZ brochure | timurrrr | BRZ Second-Gen (2022+) — General Topics | 4 | 11-01-2021 12:04 AM |
| 2022 Configurator up on Subaru.com | trippinbillies40 | BRZ Second-Gen (2022+) — General Topics | 54 | 09-24-2021 09:09 PM |
| BRZ traveling 140mph along N Fwy Houston before crashing | KDad2 | Southwest | 38 | 01-17-2018 04:47 PM |
| Clicking From Rear - Changes with Road Speed | Grimlock | Issues | Warranty | Recalls / TSB | 18 | 07-29-2016 04:30 PM |
