Drives: 2022 GR86 Premium Track bRed
2022+ Track day part numbers
I just got a GR86 and am working on buying up parts in advance of my first track day. I realized pretty quickly it's hard to find parts since the car is so new, so I figured I'd start this thread with correct part numbers and where to easily find them. This is explicitly for compatibility with oem hardware - oem struts/CA's, oem brake calipers, etc. "Oh yeah this fit after I threw on the 2013 brembos" is out of scope.
Brake Pads: Raybestos ST-43 Front #1539 lpiracing.com Raybestos ST-43 Rear #1124.16 lpiracing.com - out of stock, no restock date. Brake Rotors: Centric Plain 120 Front #120.47021 tirerack.com amazon.com Centric Plain 120 Rear # 120.47031 tirerack.com amazon.com Oil Cooling: ColorFittings Arctic Series Oil Cooler Kit # CF-OCC-02-FRS-001-XX Colorfittings.com Suspension Adjustment: Whiteline Front Camber Bolts # KCA414 amazon.com Air Filter: K&N #33-5060 amazon.com Please respond with any other relevant items which you've used and would like to recommend, and I'll try to update frequently. Last edited by andys_garage; 05-10-2022 at 03:54 PM. |
Basically everything is interchangeable with the 1st gen *except* for some air filters, and of course, excluding factory Brembos.
If you're having trouble finding something, feel free to message me and I'll get you set up properly. |
Why replace factory rotors now. You just need pads and brake fluid.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
#4 | |
I did that on my first track day in my old WRX and completely destroyed the rotors. This set of pads and rotors will go on a day before and come off a day after. Plus, they'll need to be replaced at some point anyway. |
#5 | |
You'll be good with just pads and fluid. |
| 2022 GR86 & BRZ Post Serious Performance Numbers (Nearly 1g Skidpad)! [C&D Review] | Hachiroku | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 3 | 11-24-2021 07:18 AM |
| Part Diagrams / Numbers for BRZ (like RealOEM for bmw), Part Vendors | vlad128 | BRZ First-Gen (2012+) — General Topics | 7 | 06-29-2018 04:05 PM |
| Part numbers or part diagram? | pacemkr | Engine, Exhaust, Transmission | 6 | 08-22-2016 01:44 PM |
| How do I get JDM part numbers? | InstantNoodles | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-09-2012 04:29 PM |
| part numbers | Staticfrost | BRZ First-Gen (2012+) — General Topics | 5 | 05-29-2012 12:02 PM |
