Old 05-05-2022, 06:59 PM   #1
clio
Drives: 2013 Subaru BRZ
Retro Fit PP Brembo Brakes - Questions
I have a set of PP Brembos to retro-fit on my 2013 BRZ. I have been unable to find the answers to the following questions, perhaps there may be others that are familiar with the swap that could assist:
1) Are my existing (stock) 2013 brake lines compatible?
2) The rear mounting caliper bolts - will my existing bolts suffice? (I have bought new ones for the front calipers)
Thanks
clio is offline   Reply With Quote
Old 05-09-2022, 02:14 PM   #2
Thefalls
Thefalls's Avatar
Drives: Corolla GT
The brake lines will fit.
As for the rear bolts, you will need new ones, I think.
Thefalls is offline   Reply With Quote
Old 05-09-2022, 06:25 PM   #3
clio
Thefalls - thanks
Old 06-05-2022, 07:16 PM   #4
clio
By way of follow-up to this thread, yes new bolts were required on both front and rear. The front bolts are longer (to accommodate tie bar) and the rear bolts a different pitch.
Also, whilst the brake lines fit there is a curvature to the banjo bolt steel sections that is different on the Brembo ones - therefore do not suggest using non-oem brake lines on Brembo calipers.
For anyone reading this, also note that new front and rear dust shield plates are required (unless you want to butcher your existing ones with an angle grinder which I don't advise. you don't want cut metal edges near brake hoses)
The Following 2 Users Say Thank You to clio For This Useful Post:
SpeBud07 (06-07-2022), tobin (06-08-2022)
Old 06-05-2022, 07:16 PM   #5
clio
Also, whilst the brake lines fit there is a curvature to the banjo bolt steel sections that is different on the Brembo ones - therefore do not suggest using non-Brembo brake lines on Brembo calipers.
Old 06-07-2022, 10:31 AM   #6
SpeBud07
Drives: 2013 FRS
I'm still gathering all of the parts, thanks for this update. The rear dust shields are hard to find in the US, but I agree if you're going to do it, do it right.
SpeBud07 is offline   Reply With Quote
Old 06-07-2022, 10:39 AM   #7
Espi
Espi's Avatar
Drives: 17 BRZ
just incase you haven't seen the thread for the PP brembos:
https://www.ft86club.com/forums/showthread.php?t=144662
I had a shop install mine but yea loving the brembos everyday
Espi is offline   Reply With Quote
CSG Brembo Brakes LenA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-12-2024 10:05 AM
WTB: OEM Brembo Brakes or BBK lc300 Canada Classifieds 13 11-03-2021 09:29 AM
2017 PP oem BREMBO Brakes FT86Logic Brakes, Suspension, Chassis 5 01-27-2019 03:07 AM
EVO 7 BREMBO FRONT BRAKES ON BRZ? NOTORIOUS.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-26-2016 12:24 AM
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 02:00 AM
