FRS won't start
My FRS has been parked in an underground parking lot for about 4 months due to winter/cold weather and was just attempting to start the car for the first time for spring/summer season, but the car doesn't start now.
I've never had this issue before and seemed to happened out of nowhere. I made sure my battery is charged and even tried a portable jump starter, but it keeps cranking and doesn't fire up. Only different thing I noticed (could be just bad memory) is that the fuel pump prime doesn't seem to be a loud as before (running Walbro 485), but does make a sound when I put the key into the ON position. If there is an issue with the Fuel Pump then should I be getting DTC codes? Also, I'm running an EcuTek tune for years, would EcuTek logs show fuel pressure from the the fuel pump? Also, any suggestions would be appreciated.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
You might have someone spray some starter fluid in the intake as you turn the engine over.
Well, hell, it used to work, back in the day -
#3 | |
I'm not sure if a datalog will show anything useful, but I'll try to grab a log during cranking.
| The Following User Says Thank You to Eazy-V For This Useful Post: | humfrz (04-29-2022) |
It looks like my battery is not good, but I used a jump starter and attached the logs, so would the logs indicated fuel system/pump is working?
https://datazap.me/u/eazy-v/2013-frs...12-13-16-17-35 I also have this log which was just a few minutes before and I noticed the variable "fuel quantity total I" goes from 0 to about 71, so what would that represent? https://datazap.me/u/eazy-v/2013-frs...ta=12-13-16-17
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock Last edited by Eazy-V; 04-28-2022 at 11:55 PM. Reason: Add more details |
Tried new battery and still only cranks, I'm guess it's a fueling issue and added a new datalog:
https://datazap.me/u/eazy-v/2013-frs...16-17-26-32-35 One variable on the graph is "fuel quantity total I" which shoots to 70.56, so not sure what that means and if that's normal?
Got it resolved, found that the inline fuse on my Deatschwerks fuel pump hardwire kit was completely melted
OK so now the question is why did it melt?
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (05-20-2022) |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
| Stall/No Re-start with push button start | couver | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 06-26-2020 11:32 PM |
| FS: STI engine start push start OEM plug and play | sokol | Interior Parts (Incl. Lighting) | 5 | 06-13-2019 03:12 PM |
| Car won't start. Limited with push to start. | uEih | Issues | Warranty | Recalls / TSB | 22 | 01-06-2017 12:54 PM |
| Pushed start.. didnt start | im_topher | Engine, Exhaust, Transmission | 86 | 11-29-2015 10:57 AM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
