Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-26-2022, 01:03 PM   #1
Grosbard
Drives: 2022 BRZ coming
Dealer service to maintain warranty?
Hi all! I'm reaching 1000 miles, so want to get an oil change done. (By the way, I love my BRZ!). Is it required for oil changes to be done at the dealer to maintain the factory warranty, or can I go to my trusted local mechanic? Would appreciate if anybody could point me to where this info is written down specifically (either confirming or denying) for some piece of mind. Thanks! This forum is great!
Grosbard is offline   Reply With Quote
Old 04-26-2022, 01:31 PM   #2
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Not at all necessary. You can change it yourself and retain the factory warranty - it was purchased with the car.
Panda Grahams is offline   Reply With Quote
The Following User Says Thank You to Panda Grahams For This Useful Post:
Grosbard (04-27-2022)
Old 04-26-2022, 03:37 PM   #3
OkieSnuffBox
Drives: '23 BRZ Limited
Do they give you the first one free like they used to?
If so, I'd take advantage of that since you're just trying to get any break-in materials in the oil out. Then at 4-5k get an oil change with the oil and mechanic you prefer.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 04-26-2022, 05:23 PM   #4
H380
H380's Avatar
Drives: 2022 BRZ Limited WR Blue MT
Def check the dealership included service out. My dealer has the first 4 scheduled services free. But its 150 mile round trip for me also no weekend appointments. Only Mon-Fri. No way i'm using 1/2 a Vac day for an oil change.
H380 is offline   Reply With Quote
The Following 2 Users Say Thank You to H380 For This Useful Post:
Grosbard (04-27-2022), soundman98 (04-26-2022)
Old 04-28-2022, 06:08 PM   #5
danson
Drives: 22 brz
I got this with my dealer too, who is 5 hours away. I specifically asked them if I could use it at home, and they said it was good at any subaru dealer.
Also, I asked if my local dealer would change the transmission fluid to Motul 300v (after suggestions on here) along with my break in oil change. They said they wouldnt do it as it would void my powertrain warranty. I dont have the ability to do it myself since I moved into an apartment. Any thoughts on this?
I originally tried another big chain lube place and they said they didnt have any instructions/diagrams for the 2022 model yet for transmission fluid so they also wouldnt do the service.
danson is offline   Reply With Quote
Old 04-28-2022, 08:26 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by danson View Post
...Also, I asked if my local dealer would change the transmission fluid to Motul 300v (after suggestions on here) along with my break in oil change. They said they wouldnt do it as it would void my powertrain warranty. I dont have the ability to do it myself since I moved into an apartment. Any thoughts on this?...
yeah, the vehicle is warrantied with the included and tested components/fluids. altering which fluid/components are installed void the warranty on that part, as those the alterations are no longer tested/certified to work for any length of time, or not effect other parts negatively.
now, this should only void your transmission warranty, and if you have valve cover issues, they should still be covered under the magnuson moss act, as the alterations were to the transmission, which would not effect motor leaking issues, but YMMV applies.
this guy tried taking that act further than anyone i've ever heard of, and would've lost a ton of money in legal fees had he kept going:
https://www.tacomaworld.com/threads/...ss-act.609911/
you can mod your car, or you can maintain your warranty in full. but you can't ever get both
Tcoat (04-29-2022)
Old 04-28-2022, 10:48 PM   #7
OkieSnuffBox
I don't think this is true. Even according to the owners manual it says if SUBARU oil isn't available, use one of these alternatives.
IE, use a 0w-20 Synthetic, that meets API SERVICE SN PLUS or ILSAC GF-5 standard.
Pages 381-383 of the 2022 BRZ Owners Manual.
https://ownersman.com/manuals/2022-S...-owners-manual
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 04-28-2022, 10:57 PM   #8
soundman98
soundman98's Avatar
0w-20 is motor oil. what does it say about transmission oil?
Old 04-29-2022, 10:18 AM   #9
OkieSnuffBox
I linked the manual and gave the relevant pages.....
It essentially says the same thing, "Use oils that meet these standards."
For manual transmission:
Manual Transmission Gear Oil LV 75W*3
API GL-4 SAE 75W*4
For rear differential:
Differential Gear Oil LX*3
Other gear oil that meets API GL-5 SAE 75W-85 or GL-5 SAE 75W-90 specifications*5
Old 04-29-2022, 11:55 AM   #10
API GL-4 SAE 75W*4
That is the point. They have to meet those standards. Using anything but ones that meet those standards is the issue. Doesn't have to be a certain brand.
soundman98 (04-29-2022)
Old 04-29-2022, 12:11 PM   #11
OkieSnuffBox
I mean, I thought that would be self-evident.
That if the manual calls for synthetic 0w-20 GL-5 oil, that putting in straight 50 weight GF-4 would not meet the standard.
I should know better based on what I see in the Facebook groups.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
soundman98 (04-29-2022), Tcoat (04-29-2022)
BRZ Service under warranty. DYI or Dealership? BDKane01 BRZ First-Gen (2012+) — General Topics 16 07-05-2016 02:59 PM
First warranty service maintenance vinh359 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-09-2014 01:54 PM
Good dealer to go for service/warranty in GTA? shu5892001 CANADA 8 04-18-2013 06:04 AM
Maintenance or Service Warranty? or Both? JohnAyySays Issues | Warranty | Recalls / TSB 24 03-27-2013 02:04 PM
asked dealer service manager about aftermarket/warranty NuckinFutsFR-S Issues | Warranty | Recalls / TSB 23 10-31-2012 08:24 AM
