Old 04-22-2022, 02:46 PM   #1
jordan7831
Drives: 2016 Halo FRS
Please help - stupid squirrel ate through a wire - need help finding wiring diagram
Hi everyone, I found a stupid squirrel made a nest in my engine bay today. Right near the brake booster on the driver side. Little **** tore up a lot of the foam padding under the hood to make his nest. He also started to chew through part of the outer sheath of the wiring harness that resides by the brake booster.
Call it lucky or unlucky. The squirrel chewed through a thin white wire that has silver dots on it (assuming those are to help identify the wire?). I guess it could be worse, but it could have been better.
Anyways, is anyone able to help me identify what wire this is and where it goes to? Or point me in the direction of a wiring diagram? I tried looking but I'm in a bit frustrated right now by the situation.
Thanks in advance everyone.
Originally Posted by Mr.ac View Post
My butt dnyo didn't like it
jordan7831 is offline   Reply With Quote
Old 04-22-2022, 04:02 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
link to service manuals in my sig line
jordan7831 (04-22-2022), Tcoat (04-22-2022)
Old 04-22-2022, 04:11 PM   #3
jordan7831
Thank you, Ive found some manuals but having trouble identifying the specific wire or what goes into that part of the harness
Old 04-22-2022, 07:18 PM   #4
FrickingReallySlow
Drives: 2015 FR-S
looks like its next to your brake booster? if so then its "A59" the brake fluid level warning switch
https://gt86stuff.onrender.com/t3Por...+2016+MY+FR-S+[05%2F2015+-+]&docid=989162&context=ti
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Old 04-22-2022, 07:52 PM   #5
jordan7831
Thanks for taking a look for me, its actually the big chonky part of the wiring harness that is routed behind the brake booster. I've been looking and have no clue what that wire goes to.
Old 04-22-2022, 08:06 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
doesn't really matter what the wire goes to. oem's rarely just install spare wires. and squirrels rarely chew wires that are rarely used. pull the battery terminals, wait about 15 minutes, then splice in a replacement wire--need to use adhesive-lined crimps, check all other wires in the harness while you're in there. once done, check all your fuses under the hood, and under the dash, then reconnect the battery.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Busybee (04-22-2022), Decep (04-26-2022), jordan7831 (04-23-2022), Ultramaroon (04-22-2022)
Old 04-23-2022, 12:06 AM   #7
jordan7831
Thanks for the good advice. I was hoping to find out what the wire led to so I could ensure function once repaired. Thank you for the reminder about disconnecting the battery.
The Following User Says Thank You to jordan7831 For This Useful Post:
soundman98 (04-23-2022)
2017+ brz headlight wire diagram fibber1200 Electronics | Audio | NAV | Infotainment 2 06-11-2020 04:45 PM
Wiring Diagram for BRZ OEM 12-16 DRL? leevanf Cosmetic Modification (Interior/Exterior/Lighting) 6 11-19-2019 09:44 PM
Wiring diagram for BCU 1GiantTurtle Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2014 10:10 PM
2 SVC+ 2 DVC WIRING DIAGRAM PineappleFriedRice Electronics | Audio | NAV | Infotainment 8 03-03-2014 12:12 PM
subaru brz navigation system wire diagram? watching movies usb works !! SgtBolt Audio/Visual, Electronics, Infotainment, NAV 3 06-21-2012 11:31 PM
