Old 04-16-2022, 08:29 PM   #1
wangson
wangson's Avatar
Drives: 2023 Toyota GR86 Trueno Blue
Lip is cracked, any way to fix it?
My HT Autos lip is cracked, is there any way to fix it?
Also, anyway to push the rivet back in to make the lip flush to bumper?
The paint I'm not worried (#Sharpie).
wangson is offline   Reply With Quote
Old 04-16-2022, 08:45 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
2-part epoxy to bond it back together, then sand smooth and repaint. Remove the rivet altogether and install a new one.
Old 04-16-2022, 09:54 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
really need to plastic weld it, as well as staple it to properly fix. epoxy is just going to pull apart again.
could try some plastic bonding techniques, but it requires knowing the type of plastic involved, as well as having spare material to back up the cracked area to support both sides of the crack.
and correct on the rivet-- unless it's the expandable rubber type, they're generally one-time-use, and if it pulled out, it likely tore the hole enough that you'll need to step up to the 1-4 sizes larger rivet to properly re-secure everything.
Old 04-16-2022, 10:12 PM   #4
wangson
wangson's Avatar
Will this Bondo work?
https://www.autozone.com/paint-and-b...14oz/53847_0_0
Old 04-16-2022, 10:27 PM   #5
soundman98
soundman98's Avatar
Originally Posted by wangson View Post
bondo is a name brand, not a bonding technique.
this is the specific process for ABS plastic. but there's dozens of different plastics out there, and each one has a different technique.
you need to do as he's doing and add a backer piece of the same type of material across the crack so each side of the crack is fully supported. there is no method that can simply just bond the 2 halves of hte crack back together. the crack means that part has lost support. support must be added back into the part in order for it to not crack further.
the staple method involves a $150+ tool to do, and is required for some urethanes
https://www.eastwood.com/eastwood-ho...ir-system.html
or, you can take it to a body shop, tell them to fix it, they figure it all out, warranty the work for a long time, and bill you/your insurance for it...
blsfrs (04-17-2022)
Old 04-23-2022, 12:46 PM   #6
gtpvette
Drives: 2015 FRS - FFR GTM
Based on what FT86Speed says, part is polyurethane. I'd be tempted to try to weld with a soldering iron or Harbor Freight has a cheap plastic welding kit. Would try to reenforce the back side as well. I used a soldering iron to weld my fender garnish and it turned out good. It would need filler and paint afterwards though.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
soundman98 (04-23-2022)
Old 04-27-2022, 04:19 PM   #7
gtpvette
Stumbled across this looking for something else.
soundman98 (04-27-2022)
Valenti Cracked Decep Cosmetic Modification (Interior/Exterior/Lighting) 12 11-26-2017 02:03 AM
Cracked block AceHeader-MT Tracking / Autocross / HPDE / Drifting 10 09-01-2015 09:24 PM
Cracked Oil Pan?! Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-21-2013 02:28 PM
Cracked windshield baadshah Issues | Warranty | Recalls / TSB 11 09-17-2013 08:09 PM
Cracked Rim SmsAlSuwaidi Issues | Warranty | Recalls / TSB 29 04-02-2013 01:30 PM
