Old 04-15-2022, 08:24 PM   #1
JoeS
Drives: 2016 BRZ Hyper.Blue
Rear Fender Roll - Funky Lip
I am rolling the rear fenders to make room for tires that are rubbing. When I started to roll the fenders I noticed a funky bead or lip where the roller hits the fender. After a bit, the "bead" started to come apart and peal off like some sort of tape.
Have others flat out removed the tape to roll the fender? Have you been able to roll the fender and leave the "bead/tape" in place? What happens if it is removed? It's there for a reason, right?
JoeS is offline   Reply With Quote
Old 04-20-2022, 12:28 PM   #2
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Mine is partially remove. A heated chisel (?) was used and my shop shaved 80% of it away before rolling the fender.
kevaughan is offline   Reply With Quote
Rear Fender Roll djezlee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-16-2022 05:36 PM
Rear Fender Roll djezlee Cosmetic Modification (Interior/Exterior/Lighting) 1 12-28-2020 07:57 PM
Rear fender roll in SJ? djdnz Northern California 3 04-25-2017 09:47 PM
Fender Roll/Pull FRS-IT Cosmetic Modification (Interior/Exterior/Lighting) 6 11-14-2014 10:45 PM
Fender Roll Ryaquinn Cosmetic Modification (Interior/Exterior/Lighting) 9 07-05-2013 05:49 PM
