Old 04-15-2022, 04:07 AM   #1
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Rays Dura-Nut L32, will these work?
Will these lug nuts in L32 (32mm length) be sufficient for the Enkei RPF1 17x7.5+48 wheels on stock studs? Or will I need something like the L42 (42mm length) version? My first set of aftermarket wheels and I have yet a clue about this stuff! I know the sizing should be M12x1.25, but I don't know if the nut length matters.
https://www.ftspeed.com/part/ra32121...nuts-with-lock
I also wanted to create this thread so I can garner opinions on whether I should get the blue or black. (I have a WRB car) Which looks cleaner on silver RPF1s? Pictures below taken from from members Teku18 and MyEvilMonkeys.
ItsReiko is offline   Reply With Quote
Old 04-15-2022, 08:58 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Stock studs? You won't need extended length lugnuts. Stock lugnuts are rather short closed end ones and have no issues.
If for whatever reason you'll change to longer aftermarket studs (eg. for use with thick slip-on wheel spacers) then a bit more "depends", on to how long studs and how thick spacers, and how long protruding stud length as result.
Old 04-16-2022, 03:03 PM   #3
Thefalls
Thefalls's Avatar
Drives: Corolla GT
I have the universal ones about 32mm tall also and they fit on Enkei RS+M wheels.
Thefalls is offline   Reply With Quote
[SoCal] FS: Rays Dura Nuts Lug Nuts 12x1.25 scotterson Wheels and Tires 8 12-17-2020 02:33 PM
Which one? DOALL CST ZERO-1 HYPER / Rays 57C6 / Work Kiwami? 86Toyobaru Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 09-30-2014 04:45 AM
new 2014 Wheels - RAYS VOLK Racing ZE40 | WORK Meister M1 | WORK Seeker Series RavSpec Wheels and Tires 8 06-15-2014 10:07 AM
(SYD) for sale Work XD9 and Rays 57xtreme wheels kvl Australia Classifieds 1 05-20-2014 08:14 AM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
