Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 04-11-2022, 06:45 PM   #1
Spektyr
Drives: GR86
Ride Quality, Handling on 17" vs 18"
Specifically asking those who've driven the Gen2 on both 17" wheels and 18" wheels, ideally with same/similar tires.
Is there a noticeable difference in ride quality, harshness, handling characteristics, etc, and if so how would you describe the difference? Which do you prefer and why?
Thanks in advance.
(I have 18" on mine and haven't been able to compare them to anything else, and I'm debating whether there's an advantage to having a second set of wheels/tires on 17".)
Spektyr is offline   Reply With Quote
Old 04-12-2022, 12:58 AM   #2
Edkwok99
Drives: GR86
I use 17 inch for track and oem is 18 inch for daily (same diameter). I definitely can feel more bumps and stiffness riding on the 18. Sometimes I feel like I want to throw up after meal on the 18. I am actually looking to get another set of 17 for daily driving. 18 is just not for me with the rubber band tire (215/40)
Edkwok99 is offline   Reply With Quote
Old 04-12-2022, 02:56 AM   #3
gskv
Drives: 2017 BRZ
i've just ordered a set of RCE T0 and 16" OEM JDM wheels to combat the bumpiness and stiff suspension.
gskv is offline   Reply With Quote
Old 04-13-2022, 04:17 PM   #4
Dake
Dake's Avatar
1st Gen here, but regardless it's all about that sidewall. The difference between a 40 mm and 45 mm sidewall is noticeable. So option C is go up a size on the sidewall for your 18".
Dake is offline   Reply With Quote
Old 04-13-2022, 05:09 PM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
You do know that the 40 and 45 are not the height in mm right? You do know that it is a percentage of the tread width, right?
dragoontwo is offline   Reply With Quote
The Following 5 Users Say Thank You to dragoontwo For This Useful Post:
Busybee (04-14-2022), Rustyoid (04-13-2022), soundman98 (04-14-2022), SuperTom (04-13-2022), x808drifter (04-14-2022)
Old 04-13-2022, 07:40 PM   #6
Rustyoid
Drives: 2022 GR86
I think overall weight makes more of a difference than an extra half inch of sidewall. The OEM 18s are relatively heavy, 23.x LBS if I remember correctly. Light wheels improve everything significantly
Rustyoid is offline   Reply With Quote
The Following 3 Users Say Thank You to Rustyoid For This Useful Post:
Petah78 (08-14-2022), SuperTom (04-13-2022), Yoniyama (02-26-2023)
Old 04-13-2022, 09:05 PM   #7
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
That plus you will throw off speedometer and slower acceleration with larger diameter tire.
Yep its all about the weight. Especially on the outside perimeter. On a 17 the weight of the barrel is pulled in closer.
SuperTom is offline   Reply With Quote
Old 04-13-2022, 10:56 PM   #8
Dake
Dake's Avatar
You know... I don't think I did (or if I did it fell out). I just knew one was taller than the other and assumed!
Anyway, this is true. Going from a 17" to an 18" while keeping the 45 sidewall will result in your speedo showing 3.5 mph slower than you're actually going, whereas dropping to a 40 sidewall on the 18 will only throw off the speedo by about 1 mph.
Old 04-14-2022, 12:41 AM   #9
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Gen1: switched from 17 oem wheels with Michelin AS4 (215x45) to 18x7.5 STI (from 2018 ts) with Michelin PS4S (215x40).
Maybe it’s just me but there is nothing dramatic. First time using 18 on the brz and totally fine for the daily. Almost no difference on mileage and stiffness. Everything else is stock on the 2019 brz.
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 04-14-2022, 12:58 AM   #10
drivejumpfly
Drives: Toyota
How about tire wear on the 18s? Think you can hit 7,500 miles on them with moderate driving?
drivejumpfly is offline   Reply With Quote
Old 04-14-2022, 01:00 AM   #11
Busybee
Busybee's Avatar
If you asked me, just switched 10 days ago.
Old 04-14-2022, 03:00 PM   #12
Racecomp Engineering
The tire type itself makes the most difference IMO. More than weight and sidewall (within reason).
I always caution against ultra-light wheels if your roads are extra crap because wheels can and do bend.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Busybee (04-15-2022), Dzmitry (04-18-2022), Tcoat (04-14-2022)
Old 04-14-2022, 10:11 PM   #13
Spektyr
Drives: GR86
I've got BFG Comp2 A/S on my 18" OEM wheels right now (waiting for the weather to warm up enough, consistently). The ride quality is "quite informative". You get the impression you know everything there is to know about the road surface, but it's not "was that a boy worm or a girl worm I just drove over?" Fillings don't rattle, but if you had a sore back before you get in you should probably take some Aleve ahead of time.
I'm okay with it the way it is. I also wouldn't mind taking some of the sharpness out of it as long as I don't lose much (or ideally any) of the handling quality.
I'm toying with the idea of getting a set of daily driving tires on 17" wheels and keeping the 18s for track use.
I realize that for the most part it's all about compromise - can't have everything. And the cost has to make sense.
Old 08-14-2022, 01:36 AM   #14
Yoniyama
Drives: BRZ 2018
- Andrew
My Enkei RPF-1 bent when going over a pot hole (at around 15mph).
Super-light cast wheel is more prone to bending, whereas super-light forged wheel is more prone to chipping and cracking.
Yoniyama is offline   Reply With Quote
Staggering 9" rear, 8" front handling experience? wbradley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-28-2018 02:54 AM
Anybody attending "Ride Or Die Chicago 2014" Meet? EggsAreGood Great Lakes 1 05-17-2014 12:16 AM
Meet Tr!x5tuh's Ride "HERA" (slowly) tr1x5tuh Member's Car Journals 20 02-05-2014 04:40 PM
New C&D production BRZ review... "Porsche-like Handling" Sport-Tech BRZ First-Gen (2012+) — General Topics 112 04-29-2012 01:10 AM
MotorTrend Blog: BRZ handling "better than Porsche, Godzilla and the McLaren" Kimsey47 BRZ First-Gen (2012+) — General Topics 59 04-24-2012 12:44 AM
