Old 04-06-2022, 11:19 PM   #1
jrhudson
Drives: 2016 scion frs
injector ecu flashing?
hey guys,
so i am looking for some direct injectors to my OEM block. my original DI are in my built block now and i'll be grabbing a used set on ebay. But i can only find ones that are marked with a different number than my original ones, which is 2.
i read on fb that you need to reflash the injector ecu when you change your DI numbers. But nothing on how to do this. Is this something only the dealer can do?
OR will this even matter as long as I have the same numbers match on the direct injectors?
jrhudson is offline   Reply With Quote
Old 04-11-2022, 02:57 AM   #2
steve99
Originally Posted by jrhudson View Post
hey guys,
there is no need to alter the DI injector ecu they are all same
all you need is a set of four DI injectors with same numbers on them
they can all be 1,2,3 but you need a set of say all 1 or all 2 or all 3
just dont mix numbers in a set and your good to go
Flashing from E85 to 91 Phantobe Software Tuning 18 02-16-2015 06:44 PM
Flashing cel wtf ! :/ sweetfrs Issues | Warranty | Recalls / TSB 16 12-07-2013 02:13 AM
Flashing your ECU question Blackout808 Engine, Exhaust, Transmission 3 04-05-2013 10:33 PM
anybody else see the flashing carrot??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 46 01-18-2012 09:25 AM
