Old 03-31-2022, 04:05 PM   #1
boulderbrz
Drives: 2013 Subaru BRZ
Engine ticking shortly after new engine
I recently bought a 2013 brz and almost immediately spun a bearing. After taking it into the dealer and getting a new shortblock, I am hearing a ticking sound at certain rpms that sounds somewhat similar to a valve or rod issue. Any ideas as to what this may be?
boulderbrz is offline   Reply With Quote
Old 03-31-2022, 04:10 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Locate the sound with a stethoscope, careful of rotating parts with anything dangling! A rod issue is a very pronounced knock. Most likely you are hearing the HPFP on the driver side head. It is driven off the intake cam and can be noisy. You may just be extra sensitive to noise being that you had a spun bearing already.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
humfrz (04-04-2022)
Old 03-31-2022, 08:01 PM   #3
Decep
Drives: 2013 FR-S Series 10
Thread useless without video
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 04-04-2022, 02:12 AM   #4
humfrz
Welcome to the group, there, boulderbrz -
DANG, you are hard on engines! (sorry, bad joke - ).
I'd suggest you give the new block a few miles to settle in, to see if the sound will go away (or you will get used to it).
Old 04-04-2022, 09:40 AM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The direct injectors make a ticking noise while driving. Sounds sketchy if you don't know the sound.
Old 04-04-2022, 04:34 PM   #6
radroach
Drives: car
@boulderbrz could just be the injectors, a clicking that can be annoying.
Another tapping or ticking can be from the clutch throw-out bearing. Should have been upgraded to the new subaru part #, upgraded throw out bearing, which is more reliable than the factory bearing that came with early models.
Engine Ticking and Blowby Blazer Engine, Exhaust, Transmission 13 12-09-2021 10:50 AM
engine ticking noise at idle fog Issues | Warranty | Recalls / TSB 13 11-02-2020 07:51 PM
Ticking/rattling after engine install, now won't turn over? Alfrz91 Issues | Warranty | Recalls / TSB 26 10-12-2019 08:48 AM
Ticking/rattling after engine install, turns into...? Alfrz91 Engine, Exhaust, Transmission 0 10-01-2019 01:18 AM
Loud ticking from engine Norotor Issues | Warranty | Recalls / TSB 8 04-24-2018 01:45 AM
