Old 03-28-2022, 07:44 PM   #1
Beefybork
Drives: 2013 Scion FRS
Bent Slave Cylinder Rod
Hey guys, I bought a 2013 FRS a few months ago, and started having some clutch issues recently. Took it to a good local shop, and they found that my clutch fork was cracked, and my slave cylinder pushrod was bent due to increased stress from an aftermarket clutch. They advised that I should upgrade my clutch fork, slave, and master cylinders. The tech I was talking to had a similar issue with a WRX he had done a clutch on. I've been able to find several options as far as aftermarket clutch forks and master cylinders, but can't seem to find anything other than OEM or the Autozone special for the slave. Any advice would be very appreciated, thank you.
Beefybork is offline   Reply With Quote
Old 03-28-2022, 08:02 PM   #2
Ashikabi
Ashikabi's Avatar
Other than using a bigger one from another car... I dunno about direct replacement. However, you could go to a full hydraulic unit which would delete your fork, throwout, and pivot. And replaces your slave with a hydraulic"donut". I believe the kit saw was a pretty steep 800$. But if you're bending slaves then it might be worth it. This style throwout/slave is standard on all LS engines
The Following User Says Thank You to Ashikabi For This Useful Post:
jcw99 (03-29-2022)
Old 03-28-2022, 10:07 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i don't think that hydraulic throwout bearing replacement is being made anymore. not enough interest.
Old 03-28-2022, 10:12 PM   #4
Ashikabi
Ashikabi's Avatar
For that cost I'm not surprised
Old 03-28-2022, 10:30 PM   #5
soundman98
soundman98's Avatar
the price really isn't that far out of line. knowing a few machinists, i consider it a very fair price for the machining and fab work required for what can never be a product that is produced in any meaningful volume.
i was interested in it for a while, just didn't work out for the timing of having funds available.
Old 03-28-2022, 10:35 PM   #6
Ashikabi
Ashikabi's Avatar
It may be a fair price on the manufacturing side, but that doesn't make it a good value for the customer. It doesn't do much that the stock system doesn't, but costs a great deal. If I had one to reverse engineer, I could make one for you
soundman98 (03-28-2022)
Old 03-29-2022, 09:02 AM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Cracked forks, broken pivots happen, but I've never heard of a push rod bending. What kind of "heavy duty" clutch is in the car? Are you boosted? If n/a, a stock clutch is all you need. Versus forks and pivots are good up grades. Stock master and slave should work fine with almost any clutch.
Old 03-29-2022, 09:23 AM   #8
Ashikabi
Ashikabi's Avatar
I suspect when the fork bent, it forced the slave to operate at an angle, bending it too
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
blsfrs (03-29-2022), Grady (03-29-2022), Tcoat (03-29-2022)
Old 03-29-2022, 12:35 PM   #9
Grady
Grady's Avatar
I agree the bent push rod is a result not a cause. Go get a Subaru/Toyota one then replace the fork and pivot with a Verus version. You will be good from there.
The Following 2 Users Say Thank You to Grady For This Useful Post:
blsfrs (03-29-2022), MJones_RB (03-29-2022)
Old 03-29-2022, 01:36 PM   #10
MJones_RB
MJones_RB's Avatar
Sounds like a bad install job. The slave cylinder is only driving hydraulic fluid from the master cylinder. Luckily, slave (assistant) cylinders are real cheap and easy to change out yourself. As far as the clutch fork, you can just change it out with a new stock one and get a lot of mileage out of it, or use the aftermarket ones. Also change out your pivot point and your TOB to be safe. Good luck!
MJones_RB is offline   Reply With Quote
Old 04-08-2022, 02:42 AM   #11
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
https://www.verus-engineering.com/sh...egory=39#attr=
Clutch Master Cylinder and Slave Cylinder Question oec88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 11-01-2021 03:38 AM
Slave cylinder Help vincelive123 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 05-09-2017 02:50 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
Clutch Slave Cylinder KAR Southern California 4 08-08-2015 09:25 PM
OEM Clutch Slave Cylinder $20 shipped SlowCone Transmission and Driveline 0 04-25-2015 05:07 PM
