Old 03-28-2022, 12:07 AM   #1
RuyGuy2
Dysentery Enthusiast
RuyGuy2's Avatar
Drives: 2017 toyota 86
Question Got P24B9 after supercharger install.
I installed the HKS supercharger clamped every hose replaced the fuel pump and upper injectors used the delicious tuning flex fuel kit, and I'm getting a P24B9 code which says "Evap system leak detection pump pressure sensor"
Car runs good, has no issues with fuel, doesn't get to rich or lean, only issue is the code keeps coming back. Shows up as a PDTC.
I'm at a loss for what to check next? Has anyone had this code or have had a fix for it?
Much appreciated!
Update 3/28 - Got the Subaru Repair manual for the Car. Code actually means:
The difference in pressure between the canister pressure sensor and manifold air pressure sensor is too big.
So I ran through the "Factory Diagnosis" and got to the point where it said to replace the MAP sensor, so I put the factory MAP sensor back into the car and went back through the diagnosis, and It appears to be correct. I need to go through a few cycles to make sure this works, but it appears the tune was not scaled for the MAP sensor in the Kit or there is some sort of other issue with it.
RuyGuy2 is offline   Reply With Quote
Old 03-28-2022, 12:18 AM   #2
alphasaur
friendly
Drives: 17' 86
you clamped the hoses under the intake manifold?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 03-28-2022, 04:23 AM   #3
tomm.brz
Drives: brz 2017 hksv2
is the flex kit Connect ed to evap or o2 sensor? also check the evap solenoid if it s ok or has cracks some where in the hoses
Also go back to your tuner and ask him about the code, could be related to the install of the flex kit, and maybe as easy as deactivate the DTC on the tune
The Following User Says Thank You to tomm.brz For This Useful Post:
RuyGuy2 (03-28-2022)
Old 03-28-2022, 10:13 AM   #4
RuyGuy2
RuyGuy2's Avatar
Yes, Had the Day off today so I took tested the solenoid to make sure it's holding vacuum and it does so perfectly. Put the Solenoid in and vacuum tested from the metal line and it held vacuum.
Old 03-28-2022, 10:14 AM   #5
RuyGuy2
RuyGuy2's Avatar
Second O2 sensor. I had the Day off today so I took tested the solenoid to make sure it's holding vacuum and it does so perfectly. Put the Solenoid in and vacuum tested from the metal line and it held vacuum.
delicious tuning, hks supercharger, p24b9
Supercharger install tian105 Mid-Atlantic 5 04-21-2021 11:41 PM
Supercharger install tian105 NY / NJ / CT / PA 6 03-18-2021 03:18 PM
Supercharger Install 920peeps Great Lakes 2 08-05-2016 04:15 PM
Supercharger install cost? LtS720 Forced Induction 22 10-12-2013 01:16 PM
brz vortech supercharger install? Sniper2606 Forced Induction 16 05-07-2013 04:31 PM
