Old 03-26-2022, 02:25 PM   #1
Jynx
Drives: 2013 Subaru BRZ
Weird noise in the front passenger side wheel well (i think?)
i recently got my brakes done (all 4, rotors and pads) and now after about 2 weeks with the new brakes i got a god awful sound in my passenger front wheel well. It works fine when i brake but as soon as i come to a stop and let off the brake pedal i get like tick and clunk noise and it will go away after i get moving. It also does it if I'm at a light and I'm stopped and i left off the brake a little to move forward and then stop again. its super hard to describe and i cant really get a video of it. I took it back to the shop that did it and they drove it and the damn car didn't want to do it. it comes and goes but when its there it is horrible. i left off the brake and i get a tick/grind/clunk sound. it just sounds like a clunky/grinding. my brake fluid was also flushed. has anyone had this issue?
Jynx is offline   Reply With Quote
Old 03-27-2022, 01:04 AM   #2
humfrz
My first guess would be that the caliper is sticking. You may wish to have it repaired/replaced.
Old 03-27-2022, 02:34 AM   #3
Jynx
that's what i figured. I'm taking it back to the dealership Tuesday. they looked at it once already and test drove it and they where like "oh we didn't hear it so we think its good" gonna go back and try again because ik im not paying for it because it was fine until they changed them and now i got this god awful noise so we shall see.
Old 03-27-2022, 09:26 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
need to take the wheels off to inspect, at the very least
Old 03-27-2022, 02:51 PM   #5
humfrz
Back-in-the-day, when shops did a complete brake job they used to replace the calipers with remanufactured (rebuilt) calipers.
Except Bubba's shop and he would just soak the old calipers in kerosene and give them a healthy rap with a BFH -
Old 03-27-2022, 04:42 PM   #6
Jynx
oh jesus man
Old 03-27-2022, 05:08 PM   #7
soundman98
soundman98's Avatar
I don't know that anything about that makes sense.
If you replaced the rotors and pads all the way around, that would've eliminated any 'hot spots' on the rotor.
Take the wheel off. Are all the anti-squeal clips installed? Are the brake pads installed backwards? Did they use a different model rotor that's slightly larger? Do you have a cat stuck in your wheel?
Old 03-27-2022, 05:27 PM   #8
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Could be crappy aftermarket pads that don't fit the caliper. They will shift forward with stopping and backwards when taking off. With the wheel off the ground, can you reproduce the sound by rocking the wheel back and forth?
Old 03-27-2022, 05:32 PM   #9
blsfrs
blsfrs's Avatar
Back, back, back in the day, we had drum brakes (aka press and pray). Always needed a BFH to get the drums off and some funky spring tools to get the shoes off. Wheel cylinders always leaked. And forget about actually stopping if they got wet.
Old 03-27-2022, 05:41 PM   #10
Jynx
but wouldn't the drivers side being doing it too if that was true?
Old 03-27-2022, 05:44 PM   #11
blsfrs
blsfrs's Avatar
Good point. I need to work on my cognitive skills.
Old 03-27-2022, 08:31 PM   #12
soundman98
soundman98's Avatar
not always. there's been threads in the past of dimensional variations of pads from package to package, especially on cheap pads. could also still be the anti-squeal/anti-rattle clips. they're easy to lose, and some guy's don't bother locating new one's if one makes a run for shop sewer drain.
rule #1 of "new noise, who dis?" is to first check/inspect the components changed.
#2 is to check the things that interact with the changed parts.
#3 is to chalk it up to coincidence, and realize that the problem is somewhere else, entirely unrelated to the work performed that was blamed in #1.
Old 03-27-2022, 10:59 PM   #13
humfrz
Fer sure fer sure.
Actually we had disk brakes before we had drum brakes.
BBK shown.
Old 03-28-2022, 03:09 AM   #14
soundman98
soundman98's Avatar
Organic, water-cooled brakes!
Weird Noise Coming from passenger side brz Amani_Blu Issues | Warranty | Recalls / TSB 5 10-31-2021 02:24 AM
Weird noise from the front drivers side DavidBob BRZ First-Gen (2012+) — General Topics 6 12-04-2014 11:58 PM
What is that rattling noise near the front passenger side window? tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 7 11-03-2013 07:25 PM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 05:55 PM
