Old 03-24-2022, 03:36 PM   #1
SeizeTheKarp
Drives: 2020 Hakone 86
Brake Pedal Travel after SS Lines and Race Pads
Hey Guys,
I recently did a brake overhaul on the 86 (SS lines [Stoptech], new pads/rotors [CSG-Spec CP & centric blanks], RBF [Motul 600]) and while the brake pedal is super stiff and responsive, it not longer travels enough to properly Heel-Toe. I seem to remember a thread on here about adjusting the brake pedal height but I cant seem to find it anymore. I know about various clutch pedal adjustment write-ups but cant find the thread I'm thinking of. based on looking at diagrams, I have a conceptual understanding of how to adjust the pedal height however I'm unsure as to the existence of negative side-effects with making the adjustment. Anybody have any insight?
Cheers
SeizeTheKarp is offline   Reply With Quote
Old 03-24-2022, 03:46 PM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
https://www.ft86club.com/forums/showthread.php?t=32194
Another option is to get the Verus throttle pedal spacer and leave the brakes alone.
Joon525 is offline   Reply With Quote
Old 03-24-2022, 04:12 PM   #3
Originally Posted by SeizeTheKarp View Post
Hey Guys,
Cheers
A throttle pedal spacer seems like the answer.
You'll find that if you're heel-toeing under AGGRESSIVE braking, you'll be deeper into the pedal and likely in a more "matched" position.
This is a large part of why CSG always tries to match the complete braking system (pads, calipers, rotors), to the tire and aero of the car!
Are you on the stock tires?
Old 03-24-2022, 05:28 PM   #4
SeizeTheKarp
Hey Mike,
This is Nathan. We spoke via email. I have Factory "Aero" and am on 225's.
EDIT: I agree that under aggro situations this problem may not present itself but its something I've noticed while running some of the local canyons so the answer may be I need to push the car harder.
FS (Chicago) - Winmax W5 Rear Pads, Spiegler Front Brake Lines, Stoptech Rear Lines Jamestl Brakes, Suspension, Chassis 4 01-10-2020 05:41 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
TF Brake Cooling Kit // Race Pads // Rotors // BBK // Lines // Hardware Touge Factory Brakes, Suspension, Chassis 15 02-17-2015 06:57 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
