Old 03-21-2022, 01:18 PM   #1
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
I F'd up...
Getting ready to sell/trade(probably trade since I need a new AC compressor and I don't want to fix it) the BRZ and I decided to pull off the light weight pullies that I installed shortly after I bought it.
welp, I went to pull off the crank pulley and the spacer came out with it. So I said, "F that" and put it back. cranked it up no problem and when I went to check it the crank pulley was wobbling like hell. FML! so I shut it down and now I can't get the crank pulley spacer to sit flush or even close to it. It seems like I can line things up ok but I must be doing something wrong.
HALP! How do I get this damn thing back in?
Old 03-21-2022, 01:48 PM   #2
humfrz
- that's for putting light weight pulleys on to start with.
- that's for trying to take them off.
Sorry, I have no idea about to fix your car, however, I do believe that someone will come along soon to help you out.
Old 03-21-2022, 02:24 PM   #3
echo419
echo419's Avatar
I'm really dumb.... crap, I'm going to have to run for public office now.
Old 03-21-2022, 02:31 PM   #4
BlkTrax
Drives: Car
You didn't get the keyway lined up, and likely mushroomed the key on the crank.
If you get some small files, you can clean up the keyway on the sleeve and get in there and clean up the edges of the key itself.
You're going to need a new seal as you'll tear it up trying to file the key.
Otherwise it's pulling the front cover, and the chains to replace the key itself.
BlkTrax is offline   Reply With Quote
Old 03-21-2022, 02:45 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
At first I thanked and then I realized that the suggestion may have been to file the key in place.
Please don't introduce steel shavings into the crankcase. It's almost 100% that the key is deformed enough to warrant replacement. Try chamfering the opening for the keyway on the sleeve and see if you can get it to start. If it goes, you dodged a bullet. Still an awful hidden problem to pass on to someone else. Do the right thing.
Old 03-21-2022, 03:44 PM   #6
humfrz
Old 03-21-2022, 04:42 PM   #7
echo419
echo419's Avatar
10 to 1 that's exactly what happened. fml.
I guess now the only question is how hard is the steel on the spacer.
Old 03-21-2022, 05:13 PM   #8
BlkTrax
Drives: Car
Had to do this back in 2013, customer didn't want to pull the cover. Took about an hour of filing both, wiped the crank with a cloth, lil bit of brake clean, replaced the seal, and did and oil change.
Square and Triangle files got it done
https://www.amazon.com/Key-File-Set-6/dp/B0058ECM5Y
Old 03-21-2022, 05:18 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have one of those spacers if yours is too F'ed up. I can pull the key out of my spare engine too. I'd want to pull the timing cover and make sure you didn't crack the timing chain gear, we have seen that happen before in other threads.
Old 03-21-2022, 06:13 PM   #10
echo419
echo419's Avatar
awesome! Thanks!
I'll let you know tomorrow after I try to get this thing to fit.
Old 03-25-2022, 11:06 AM   #11
echo419
echo419's Avatar
Got it grinded down and put together. Everything is running great now. Thanks for all the input.
Old 03-27-2022, 01:08 AM   #12
humfrz
Are you related to Bubba?
Old 03-27-2022, 09:27 AM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
we're all related to bubba!
Old 03-28-2022, 12:32 PM   #14
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I know that it's too little-too late but lookie what I forund.
https://www.ft86club.com/forums/showthread.php?t=26386
