Human
Drives: 2015 BRZ Black
New to audio, looking to upgrade.
I'm looking at the OEM Audio+ Front Speaker Upgrade for a 2015 BRZ https://oemaudioplus.com/product/front-speaker-frz/ and wanted to know if I need to or should upgrade the stock amp too? I'd realistically want a plug and play in the same spot if i did upgrade the amp. I'm not looking to put an sub in the trunk. I will also get a new head unit for android auto.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
ProCrastinationConsultant
oem+'s attitude has always been to maintain a plug-n-play solution to everything. that particular upgrade path of just the speakers is specifically intended to leave everything as-is in the vehicle.
the speakers that they sell have never been all that spectacular spec-wise--those are a maybe $150 upgrade from any other aftermarket audio brand. it's important to remember that the majority of the purchase cost with any oem+ purchase is in the backend installation simplicity(both instructions, and speakers maintaining toyota-spec connectors/wiring harnesses for direct-swaps) and post-purchase support.
Drives: FRS
It sounds like you want something plug and play. You should go for it but as previous poster mentioned you do lose quality for convenience. It should make a big difference compared to stock. If you decide to spend about the same amount piecing together your own system with the same budget, you will blow awayy the oemplus.
| Anyone looking for OEM Audio Plus 450Q reference audio upgrade? | Blueaudi18 | New England | 2 | 07-19-2017 12:09 PM |
| Looking for OEM AUDIO PLUS UPGRADE,OR ? | SuperKazRacing | Audio/Visual, Electronics, Infotainment, NAV | 0 | 09-24-2013 07:37 PM |
| Audio Upgrade | brian_c_m | AFRICA | 340 | 07-29-2013 01:06 PM |
| 'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 09:45 PM |
| OEM Audio Plus upgrade | cgrey | Electronics | Audio | NAV | Infotainment | 6 | 09-14-2012 10:36 PM |
