Old 03-10-2022, 07:13 PM   #1
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
2022 OEM shift knob on first gen cars
Are they still the same thread pitch and fit on the older cars? They are available now, just a bit expensive and wanna confirm before getting one.
Plumbus is offline   Reply With Quote
Old 03-10-2022, 07:15 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The thread pitch is the same, but they are wider in the reverse lockout area.
dragoontwo is offline   Reply With Quote
Old 03-10-2022, 09:11 PM   #3
KillerBMotorsport
KillerBMotorsport's Avatar
^ this.
I hear Killer B has $29 Delrin knobs
KillerBMotorsport is offline   Reply With Quote
Old 03-10-2022, 10:43 PM   #4
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Would that present a clearance issue or just aesthetic issue? Is it noticeable/bad looking?
Originally Posted by KillerBMotorsport View Post
^ this.
https://www.killerbmotorsport.net/ro...kout.html.html
How much does this one weigh? And are they pre-tapped or you tap the thread the first time you thread them in?
Old 03-11-2022, 02:15 PM   #5
KillerBMotorsport
They are already tapped.
IDK the weight off the top of my head, but our Delrin Knob is definitely lighter than OEM.
Old 03-11-2022, 03:05 PM   #6
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
How is the sizing of your knob, i.e. diameter, compared to the OEM knob on a '22?
I don't want a huge ball on the end of the shifter, but find the OEM one a bit smaller than I've had on other vehicles and would like something a little larger. From the images on the Killer B site it looks like it might be actually smaller than OEM, but it's hard to tell for sure. Most sites talk about weight, but not size.
Desertnate is offline   Reply With Quote
Old 03-11-2022, 08:32 PM   #7
KillerBMotorsport
I'll put some calipers on the OEM on Monday. Our Delrin Knob is 50mm.
Old 03-11-2022, 09:26 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Close enough, stock knob is 49mm.
Old 03-11-2022, 10:09 PM   #9
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
In addition to their "Round Knob w/Rev Lockout", there's also their WRC knob & extension for those that want a little extra height (closer to steering wheel).
This is one my favourite knobs (and I've tried around 10 different knobs). My knob of choice for track days.
NLSP is offline   Reply With Quote
Old 03-12-2022, 12:59 PM   #10
Desertnate
Spelling Impaired
Thank you both! Still might be worth it for a better feel in the hand even if it's essentially the same size.
Old 04-07-2022, 10:02 AM   #11
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
STi shift knob vs '17+ OEM
Sent from my SM-G781W using Tapatalk
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 04-07-2022, 12:57 PM   #12
KillerBMotorsport
Great to hear. Thanks so much for using our products!
Just got some calipers on the Gen2 knob and the measurements are the same. Same leather pattern. The only difference looks like the trim rings. On the 22 they are black, not silver.
gear shift knob, second gen
2022 remotes on old cars gpvecchi Electronics | Audio | NAV | Infotainment 9 02-09-2022 12:59 AM
Brand New STI shift knob for 2022 BRZ jyelen Interior Parts (Incl. Lighting) 3 12-13-2021 08:04 PM
lathewerks shift knob, stock shift knob Ashikabi Interior Parts (Incl. Lighting) 2 02-29-2020 10:05 AM
