Drives: BRZ Limited
C 112 code?
Hi,
I have a P3 vent gauge and usually when I get a CEL code it will readout P00XX, etc.. However, I recently got a code that read out as C 112. I could not find anything on a "C" code and was wondering what that was. It doesn't seem like a CEL code as those output as "P0000" and not "C 000". Anybody have any ideas? Last edited by nwgabrz; 03-09-2022 at 09:52 AM. Reason: Added image |
Yeah C is a valid OBDII code letter but it's not one Subaru uses as far I know. Only P or U. Unless maybe it's a non-engine related code or something? When you scan your OBDII port with another device do you see the same code?
Sent from my SM-G975U using Tapatalk Attachment 210194 Last edited by p1l0t; 03-08-2022 at 04:04 PM. Reason: Added PDF |
#4 | |
Drives: BRZ Limited
I've edited the OP to add a photo. P.S. your attached PDF doesn't seem to work for some reason. |
#5 | |
Drives: BRZ Limited
Drives: Crapcan
"U" and "C" are usually communication DTC's, "P" are engine DTC's. I could only find 2 C's on the DTC chart and that isn't one of them and neither pertain to our cars and should come up that I could see. I wish I could remember the one guys username here, he would know.
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 11:27 AM |
| DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 | Trap63 | DIY (Do-It-Yourself) Guides | 0 | 06-14-2018 04:52 AM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 08:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 01:27 AM |
