Old 03-07-2022, 08:42 PM   #1
multyvers87
multyvers87's Avatar
Drives: 2015 subaru brz
ARE TRD LOWERING SPRINGS GOOD?
Ive been looking for some decent lowering springs, and im currently stuck between the skunk 2 lowering springs and the trd ones, but I just want to know more about the trd springs, are they good? Hows normal driving as a DD, still smooth like oem, or a lil stiffer? How do they handle turns and the occasional back road? I cant teally find any in depth answers any where...
Sent from my SM-G986U using Tapatalk
multyvers87 is offline   Reply With Quote
Old 03-07-2022, 09:46 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
They lower gud, just about as gud as any other lowering spring.
Also TRD-USA lowering springs are made by Eibach, a big OEM. The TRD springs are comparable to the Eibach Pro spring kit for the car.
They are moderate as far as lowering springs go (~1.0" drop), so they are stiffer to accommodate that. However, the Eibach Pro line (and by extension the TRD springs) usually try to strike a balance between ride comfort and lowering, so your quality of life shouldn't suffer while being able to enjoy sharper response.
EndlessAzure is offline   Reply With Quote
Old 03-08-2022, 01:15 PM   #3
MJones_RB
MJones_RB's Avatar
The TRD lowering springs are good for a couple reasons; they were designed to be easy to slip in and not require an alignment afterward. They don't affect the ride quality the way coilovers would. If you want a stiffer suspension, get thicker sway bars. TRD makes some decent swaybars for our cars. Good luck!
MJones_RB is offline   Reply With Quote
Old 03-09-2022, 06:30 PM   #4
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I had them on my 2nd FRS, still gave a decent ride and the drop was nearly perfect just needed a little more poke :p
HKz is offline   Reply With Quote
BRZ with TRD Lowering Springs rbatyko Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-16-2020 01:53 PM
WTB: Lowering springs SLVRSRFR Canada Classifieds 10 05-10-2016 02:47 PM
Are Tein H-Tech lowering spring good? Jfheisenberg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-22-2015 10:34 AM
Lowering car with springs... What else do I need? SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-25-2013 10:39 PM
whats good lowering springs for frs? jsn711 CANADA 14 01-13-2013 06:09 PM
