Drives: Toyota
Suitable flywheel holding tool?
Anyone have a P/N for a universal type flywheel holding tool that will work on the FA20?
Drives: Car
If you mean for torqueing the flywheel bolts to the crank.
Just use a flat piece of steel, drill one hole big enough to slide over the dowel bolt on the block and a second hole to loosely bolt into a flywheel clutch pressure plate bolt hole. |
| The Following User Says Thank You to BlkTrax For This Useful Post: | humfrz (03-08-2022) |
| ALL SOLD - OEM AT flywheel, torque converter, trans cooler, floor shifter | frs_adrian | Transmission and Driveline | 2 | 12-24-2022 03:21 AM |
| OFT is really suitable for FI Systems? | AEBRacing | Software Tuning | 17 | 08-16-2020 08:27 PM |
| Is Toronto suitable for the Lowered Life? | daiheadjai | CANADA | 29 | 05-15-2016 04:03 PM |
| OFT Maps suitable for UK fuels | Gringosteve | Software Tuning | 14 | 03-31-2016 07:40 AM |
