Old 03-06-2022, 06:22 PM   #1
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
2017 Toy 86 rear speakers
Is there any aftermarket speakers that will directly replace the stock ones in the rear seat area?
Crutchfield shows nothing ?? Any tips appreciated.
22R
22R is offline   Reply With Quote
Old 03-06-2022, 07:45 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
They're the same as the dash speakers. So many 3.5" will work. But the next question is if it's worth the effort. Most will say no.
Old 03-06-2022, 08:07 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
There isn't anything particularly special about the rear speakers either physically or electrically. I believe they are identical to the dash speakers with the exception of a little additional wiring to function correctly with the front tweeters. (Thanks to MugsBRZ for the images below.) I don't know why there isn't a direct replacement but it wouldn't be difficult to adapt something as there is ample room behind the panel. If you have access to a 3D printer you might consider these 6.5" adapters:
https://www.youmagine.com/designs/6-...racket-for-brz
Another opinion put forth on the forum is why mess with the rear speakers? Focus on the dash/door speakers and add a proper sub-woofer in the trunk.
LimitedSlip is offline   Reply With Quote
Old 03-06-2022, 11:44 PM   #4
soundman98
soundman98's Avatar
major difference between the front dash speakers and rear speakers is that the dash speakers have a capacitor that drops bass response below (IIRC) 6khz. an oem version of the name-brand product "bass blockers".
there's nothing wrong with installing 6.5's back there, but with just the L-bracket hanging back there, there's neither the vibration resistance support, or even a a concept of enough of an enclosure to get any sort of reasonable response out of them.
so the solution to a larger speaker is both a new bracket that better supports the speaker from 3 points instead of just 2, as well as building some sort of back-box/enclosure to better the bass response.
but all of that only works if you've already replaced the head unit, as i'm led to believe by others that have tried it that the oem head unit doesn't provide enough wattage or a full frequency range to the rear speakers.
mine are still installed. but disabled at the head unit. i don't miss them.
Old 03-07-2022, 07:02 PM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I will add my comment in the form of a question:
When you go to a concert to see your favorite band play, do you sit (or stand) with your back towards the performance?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 03-07-2022, 09:27 PM   #6
soundman98
soundman98's Avatar
it depends on who's behind you!
FS: 2017 Stock speakers - All Drambeenie Audio/Visual, Electronics, Infotainment, NAV 1 03-15-2022 01:17 PM
2017 BRZ, no Starlink, Pioneer & Maestro = No Door Speakers haohmaru Electronics | Audio | NAV | Infotainment 2 06-23-2019 07:31 PM
Has anyone tried to replace the rear speakers with a sub and/or larger speakers? soilent Electronics | Audio | NAV | Infotainment 9 12-28-2017 03:48 PM
FS: 2017 Stock speakers Drambeenie Interior Parts (Incl. Lighting) 0 05-04-2017 07:12 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
