Old 02-20-2022, 07:51 PM   #1
turboencabulatr
turboencabulatr's Avatar
Drives: 2013 brz redheaded stepchild
VALVE ROCKER RETAINERS
Does anybody using rocker retainers have feedback, good or bad?
turboencabulatr is offline   Reply With Quote
Old 02-20-2022, 11:06 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
I have a set, but I haven't installed them. I decided to k swap instead. If you decide to run them let me know. You could buy mine instead of waiting to get them from Australia.
Jdmjunkie is offline   Reply With Quote
Old 02-21-2022, 05:46 AM   #3
makinen
makinen's Avatar
Drives: Toyota 86
I've made my own and those retainers are still working well with beehive valve springs.
I recommend to do it when you have an engine down.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 02-21-2022, 01:45 PM   #4
turboencabulatr
Good to hear. What type of driving useage have you subjected them to and how many miles so far?
Old 02-22-2022, 02:03 AM   #5
makinen
makinen's Avatar
Drives: Toyota 86
8000 RPM lover, but no track use currently. Hopping over speed bumps by left foot braking.
About 8000 miles after installation maybe.
Old 02-24-2022, 02:27 PM   #6
RFB
RFB's Avatar
Drives: FRS
I had them installed when I replaced crank, pistons etc. , and at the same time installed titanium valve springs (had it done before the spring recall was known LOL !).
I thought it was necessary for my forged internals. Not needed for a stock motor.
Been tracking the car since new, and several years on the built motor, working great !
RFB is offline   Reply With Quote
Old 02-24-2022, 02:34 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stock NA motors are known to kick out the rocker arms. I lost one on track. Others have lost them just driving around normally.
Old 02-24-2022, 03:22 PM   #8
RFB
RFB's Avatar
Drives: FRS
I've heard it has happened on stock motors, but rare up here, because of cooler climate, cooler motors maybe ?
I've seen and know of several stock motors blown on tracks, but its always in the usual places.
Never seen one spit out a rocker arm.
BUT worth doing if the head is off as its cheap insurance .
Old 02-24-2022, 04:09 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The issue is rocker arm geometry. It was updated in 14', but is still a potential issue. 14' and up has a longer valve stem and a deeper recess in the rocker pivot though it can, and has happened to newer motors. makinen's failed driving on the street at low RPM's. He has video in the original thread on these.
https://www.ft86club.com/forums/showthread.php?t=142047
Need cam/rocker info Phantom_9192 Engine, Exhaust, Transmission 0 08-27-2021 01:57 PM
Rocker Arm Failure Worstenemy453 Issues | Warranty | Recalls / TSB 65 10-12-2019 08:50 AM
Rocker arm failed displacedTexan Issues | Warranty | Recalls / TSB 77 08-22-2018 06:16 PM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 07:47 PM
