Old 02-02-2022, 09:23 AM   #1
Dirtydan75
Dirtydan75's Avatar
Drives: Asphalt/Primer Turbo Widebody BRZ
2013 Subaru BRZ Limited 6MT (Miami, FL) - Turbo - Rocket Bunny - 75k Miles
Up for sale is my turbocharged 2013 Subaru BRZ Limited in Dark Grey Metallic (61K). The car currently has 74,700 miles and a CLEAN Florida title. There is no rust, and the car has never been in an accident. The car is in Miami, FL. I am more than willing to coordinate shipping with any potential buyers, at their expense.
I purchased the car in October of 2014 with approximately 8,500 miles. It was initially used by a Subaru of Fort Myers as a dealer demo car before being sold to me. I love this car so much and have put so much energy, time and passion into this build. However, it is time for me to move on to bigger and better things. My wife and I just sold our house, bought a fifth wheel camper and plan to travel the US living our best lives financially free. Instead of keeping the car in storage and having her rot away, I would rather sell it to someone who would appreciate it as much as I do and take the time to finish what I started.
Currnetly running at 10psi on 93. The car is setup to run e85, just needs the tune from Openflash. Turbo was installed in September 2017 at 60k miles after I purchased a daily. The car is perfect mechanically and runs great. I just finished changing the oil, flushing the radiator and installing the rear STI Brembo brakes and Fortune Auto 500 coilovers. The suspension and breaking are so well balanced, it feels AMAZING. I always wanted to take her to the track, that’s what I was building her for, but never got the chance. The only real issue is the exterior paint. This was my first build where I decided to go widebody. I have done all the work to the car myself. No one else has ever touched this car. The front bumper, front quarter panels, hood, rear bumper and side skirts need to be color matched to the rest of the body. Let me explain why this is.
All body panels and bumpers are OEM. The front fenders were replaced when I was first installing the Rocket Bunny Front over fenders. One of the fenders I cut too much and the other I put a dent in when placed by hand on it to help lift myself up from the ground. I swapped the front bumper for an OEM FR-S bumper so it would line up perfectly with the Rocket Bunny kit. I hate the way kit lined up with the BRZ bumper as it was not designed for it. I had to buy a new hood after I made a pretty big mistake when cutting out the hole for the exhaust. The rear bumper was also replaced for this reason. I was cutting out the diffuser part to give it a more aggressive look and made a big oops the first time cutting it. The side skirts are from the Scion FR-S Release Series 1.0. I love the way these lined up with the V1 kit. The trunk was purchased when I installed the Battle Aero wing because the Limited trunk has the holes for the OEM spoiler. The car will come with that trunk also which has the RB V2 wing on it. The paint on the rest of the body is just fine. The car was plasti dipped at one point and I sprayed it thin in some areas. I will be removing what remains by the end of the week.
I am asking $15,000 OBO for the car. I feel the price is fair considering all the modifications and that it only needs paint on removable body panels. I have a complete parts list and pictures below. As you can see, I have put a lot of money and time into this build. Shoot me a message if you have any questions!
Engine
Speed by Design SBD400X Turbo Kit
Speed By Design Pre-Welded Oil Pan
FT86 Speed Factory Hater Pipe Hood Exit Exhaust
Openflash Tablet V1
Openflash Performance Flex Fuel Kit
Custom E-Tuning by Openflash Performance
OMNI-Power 3 Bar MAP Sensor
STI PCV Valve
GrimmSpeed Manual Boost Controller
DIFtech Lightweight Battery Tray for Braille B106
Braille B106 Lightweight AGM Battery
Crawford Performance Air Oil Separator
Circuit Werks Aluminum Alternator Pulley - Blue
Circuit Werks Aluminum Crankshaft Pulley - Blue
Torque Solution Engine Mounts
Torque Solution Billet Aluminum Cam Plate
SuperTek Master Cylinder Brace
Mishimoto Performance Aluminum Radiator
Mishimoto Silicone Radiator Hose Kit
Mishimoto Racing Thermostat
Mishimoto 10-Row Oil Cooler
Setrab Thermostatic Sandwich Oil Filter Adapter
PERRIN Oil Sandwich Adapter
Finish Line Factory 10 AN Fittings
Fragola Hose Series 8000 Push-Lite Braided Fiber -10 AN
Fragola Push Lock Clamps
Fumoto F108S Engine Oil Drain Valve
Fumoto Lever Clip
Royal Purple 36530 HPS SAE 5W-30 High Performance Street Motor Oil with Synerlec
Transmission
ACT XT/Race Sprung 6 Pad Clutch Kit w/ Flywheel
Forcedfab Transmission Mount Stiffener
Whiteline Gearbox Positive Shift Kit
Verus Throw Out Bearing and Clip Kit
Verus Billet Clutch Fork Pivot
Verus Forged 4130 Clutch Fork
MTEC Shift Spring Kit
PERRIN Shifter Bushing
Redline MT-90 Gear Oil
Suspension
Fortune Auto 500 Series Coilovers
GTSPEC Front Strut Brace
GTSPEC Rear Strut Brace
GTSPEC Front 4 Point Subframe Reinforcement Tie Brace
PERRIN Steering Rack Lockdown
Megan Racing Inner Tie Rods
Megan Racing Front Roll Center Adjusters
Mean Racing Rear Subframe Bushing Inserts
Megan Racing Rear Differential Mount Support Bar – Limited Edition Pink
Megan Racing Rear Lower Control Arm – Limited Edition Pink
Megan Racing Rear Trailing Arms – Limited Edition Pink
Megan Racing Rear Lower Tie Bar – Limited Edition Pink
Parts Shop Max (PBM) Solid Subframe Risers – Not Currently Installed but Included with Car
Parts Shop Max (PBM) Solid Diff Riser – Not Currently Installed but Included with Car
Brakes
MOTUL DOT 5.1 Brake Fluid
Cadillac ATS Brembo Calipers - Front
CTSVBrakeSwap.com Subaru 4 Piston ATS Caliper Big Brake Bracket Kit
DBA T3 Clubspec 4000 Series Slotted Rotors - Front
2017 STI Brembo Calipers - Rear
DBA T2 Street Series Slotted Rotors - Rear
StopTech Stainless Steel Brake Lines - Front & Rear – Not Currently Installed but Included with Car
Wheels & Tires
RAYS Gram Lights 57DR - 18x9.5 +12 5x114.3 - Gun Blue 2 - Front
Kenda Kaiser KR20A 255/35R18 - Front
Hub Centric Wheel Adapter 5x100 to 5x114.3 - 15MM - Front
RAYS Gram Lights 57DR - 18x10.5 +12 5x114.3 - Gun Blue 2 – Rear
Kenda Kaiser KR20A 275/35R18 - Rear
Hub Centric Wheel Adapter 5x100 to 5x114.3 - 20MM - Rear
RAYS 35mm Aluminum Blue Lug Nuts and Lock Set 12x1.25
RAYS Gram Lights GL Center Cap Black Chrome - Blue 57DR
Hub Centric Ring 56.1 to 73.1
Exterior
GReddy Rocket Bunny V1 Front & Rear Fenders
APR Formula GT3 Carbon Fiber Mirrors
Innovated Dynamics Brake/Intake Ducts - FRP
Infamous Design Front Canards
2015 OEM Scion FR-S Front Bumper
2017 OEM Taillights
Aerocatch 120 Above Panel Series Hood Latches
Drift Armor PRO Front Bash Bar
Scion FR-S Release Series 1.0 Side Skirts
BattleAero Chassis Mounted Splitter - Large
BattleAero Trunk Mounted Swan Neck 66” Wing - Car will also come with second trunk with Rocket Bunny V2 Wing.
Interior
Cusco Sports Shift Knob
Cusco E-Brake Replacement Button – Silver
P2M Race Floor Mats
Toyota OEM JDM RC Edition Black Interior Door Handle Lock Levers - Driver and Passenger
Toyota OEM Center Sliding Armrest with Red Stitching
Toyota OEM JDM Speaker Trim Piece Pads with Red Stitching
Toyota OEM JDM Knee Pads with Red Stitching
Toyota OEM 2017 86 Red Stitching Gauge Trim
Toyota OEM JDM Black Shifter Trim
Toyota OEM JDM Black Door Handles
Toyota OEM JDM 2017 Black MT Traction Control Buttons
Subaru OEM Leatherette Dash Trim with Red Stitching
Spare Parts
OEM Truck with OEM Liner and Rocket Bunny V2 Spoiler
OEM 2017 “Shark Fin” Antenna
OEM Rear Axel
OEM Side View Mirrors with Helix Convex Mirrors that have “Objects in Mirror are Losing”
Dirtydan75 is offline   Reply With Quote
Old 03-17-2022, 10:51 PM   #2
Dirtydan75
Dirtydan75's Avatar
Bump
Old 04-09-2022, 10:56 AM   #3
Dirtydan75
Dirtydan75's Avatar
Bump PRICE DROP
brz, bunny, rocket, subaru, turbo
FS 2013 Subaru BRZ Limited 27.7k miles woasuby Cars for Sale/Trade 0 04-12-2018 12:07 PM
2013 Molded Rocket Bunny Subaru BRZ $28,400 asphaltkyle Want-To-Buy Requests 1 03-07-2015 08:10 PM
Hot Lava Rocket Bunny Supercharged Magazine Cover 2013 Scion FRS 869 Miles $39.9K RWDRIFT Cars for Sale/Trade 23 07-01-2013 03:35 PM
