Drives: 2015 Tacoma
Non overkill suspension?
Looking for suspension that will keep the stock characteristics of the car, but will be suited for a mild drop (~1”) with track appropriate wheels and tires. I’d like to do a max of 5 track days a season. Should I look into springs/shocks or a coilover system? I think the end goal is to run a 235 series tire on an 18x8.5 or 18x8 wheel. This will be for a 2022 BRZ bought for weekend warrior fun. Had racecomp yellows on my first gen, and I’m leaning towards the racecomp ss coils for the 2nd gen.
"Bah Weep Granah Weep Nini Bong"
Old: 2013 Arengto FR-S Current: 2015 Tacoma/2020 Sequoia Pro Future: 2022 CWP Limited Est Delivery 06/22 |
TRACKBREAD
I’d look at RCE yellows again with your choice of shock (stock/Koni/Bilstein).
Coilovers get stiff fast. Stock springs are around 3.5kg/mm, RCE yellows are ~4.5kg/mm. I can’t think of any coilover that’s under 6kg/mm. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | RToyo86 (02-03-2022) |
Drives: '13 Whiteout
I run Bilstein B6 and H&R springs and am happy with it. I don’t like to adjust things so this works for me. In addition to -3 front and -2 rear camber and better sway bars the car is well balanced on the track
Drives: 2015 Tacoma
Will spring/shock combo limit me as far as wheels/tire choices? I need functional over form.
| The Following User Says Thank You to TommyW For This Useful Post: | euroshowoff (01-29-2022) |
Drives: '22 BRZ Limited 6MT
| The Following User Says Thank You to sds For This Useful Post: | Yoshoobaroo (02-04-2022) |
ST are also pretty soft, looks like less then 4k F/5k R, and twin tubes are pretty good for road comfort. Racecomp SS are slight stiffer then ST iirc, might be an acceptable tradeoff for road comfort and track performance.
Edit: Ohlins were like 4k/3k for awhile Lowering springs will allow you to use 8” wide wheels just fine in +35-+45 offset (lower offset means more camber from bolts though, you can get -3 with +40 on stock diameter springs), 225 wide tires are more widely available then 235 which is a bit of an oddball size, most manufacturers skip over it for niche track oriented compounds and go to 245 which is happier on a 9” or wider. Last edited by strat61caster; 02-03-2022 at 01:23 PM. |
The Fail Boat
Drives: CWP S.B.
ST Coilover V3
If it's good enough for drift King, It's good enough for you.
| The Following User Says Thank You to chaoskaze For This Useful Post: | Teseo (02-04-2022) |
Purist
Drives: 2013 FRS - Hot Lava
Structurally the same as Racecomp Superstreets (SS-1). Do the V3's have both bump and rebound adjust?
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#10 |
Drives: Toyota 86
ST XTA 3 are 3 way adjustable tho, without external canisters and different valving from the hybrid mono/twin tube design from Clubsport 3 way for example…they’re still amazing for that price, springs are 6k 5k like every ST coils
#11 |
Drives: 2016 HyperBlue
I was in a similar situation and went with the SS-1 and have been extremely happy with them. They work great for autocross/track on the stiffest settings and are still very easy to live with for daily driving on the softer settings. Camber adjustment on these was a big selling point vs springs and shocks.
| The Following 2 Users Say Thank You to nathand For This Useful Post: | Racecomp Engineering (02-04-2022), Yoshoobaroo (02-06-2022) |
#12 |
Drives: 2013 WRB BRZ 6MT
If you're just daily driving and want to reduce wheel gap, 1 inch lowering springs are the way to go. If you're going to be tracking the car or want to run wider tire setups, start looking into coilovers with adjustable tophats. A good street coilover capable of mild track work is the RCE SS1 which I've seen mentioned in this thread and I personally use. If you want something geared to more serious track work, we'd need more detail about your setup, skill level, budget, etc.
#13 |
Famous Potatoes
Drives: '15 ultramarine
Stock with TRD lowering springs and swaybars was slightly stiffer ride then stock. Big change was bilstein B6; MUCH stiffer ride than stock.
#14 |
Check out the CSG Spec Flex A. Rides better than stock. Handles on track. Adjust clicks to go from street car to track car.
https://www.ft86club.com/forums/showthread.php?t=126107 It's just been finished for the 2022, and should arrive in April/May ish. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | gcmak (02-14-2022) |
| How overkill is 245/35 vs 225/40 tires? | Skyehigh55 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 05-04-2020 02:30 PM |
| Perrin 25mm rear swaybar overkill? | 5150 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 04-27-2018 12:47 PM |
| For stockish power Nitto NT01's R-Comps overkill? | jflogerzi | Tracking / Autocross / HPDE / Drifting | 73 | 03-05-2015 01:38 AM |
| Second Skin 13.5 SqFt Door Pack and 9 SqFt Overkill Pro | Caspian | Audio/Visual, Electronics, Infotainment, NAV | 1 | 11-10-2014 10:41 PM |
| Advan AD08 - overkill? | typericey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 05-31-2013 05:40 PM |
