Old 01-14-2022, 08:01 AM   #1
grumpysnapper
grumpysnapper's Avatar
Rear mounted water "helper" radiator
Belts and braces...
Basically, I never want to worry about cooling ever again...no matter what the situation, so I'm adding a small "helper" water radiator inside the rear bumper (in addition to a second oil cooler up front).
Its 280x189x37mm (21 Row) Plate and Fin with a 9" Spal puller fan.
An electric booster pump will feed it (which can run up to 27 litres per min), with both fan and pump triggered whenever the front radiator fans activate.
There is a heap of vacant space in the rear bumper shell, and with the reversing light unit removed, quite a decent sized vent directly into what I would assume is a low pressure zone. (A serious amount of flow exits when the fan is active)
I see it mainly as a helper with cooling down straight after a hard run.
The radiator is mounted and the pump is in place and the electrics are live, so now I'm in the process of running (5/8) hose from front to rear..and back.
There will be wire mesh protecting both sides, and even though it looks vulnerable to rocks etc from under the car, it is surprisingly well protected...sitting up fairly high, and with a large muffler in front (which I am going to wrap to all but stop any radiant heat).
I'm going to be fascinated to see if it works and how it goes (fingers crossed!).
grumpysnapper is offline   Reply With Quote
Old 01-14-2022, 08:04 AM   #2
Ashikabi
Ashikabi's Avatar
Where are you pulling oil from?
Old 01-14-2022, 08:08 AM   #3
grumpysnapper
Coolant
Old 01-14-2022, 08:11 AM   #4
Ashikabi
Ashikabi's Avatar
Originally Posted by grumpysnapper View Post
Coolant
Oh I saw you say oil cooler and assumed this was that. But I remember you from your other thread now. Why not just get a bigger radiator? That would offer much more cooling than this thing. Not that this won't work, cuz it will. I just don't believe it will work as well
Old 01-14-2022, 08:20 AM   #5
grumpysnapper
Yeah, already have a bigger and more efficient front (PWR) radiator, and I quite like the idea of taking any heat I can away from the engine bay area.
Old 01-14-2022, 08:58 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
could also consider running an aluminum hard line for most of the length underneath the body. it's not going to add much cooling, but would add more cooling than a rubber line in the same scenario...
grumpysnapper (01-15-2022)
Old 01-16-2022, 03:27 PM   #7
norcalpb
norcalpb's Avatar
I dig it, also reminds me of the diff cooler openings on the cup cars.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
grumpysnapper (01-17-2022), soundman98 (01-16-2022)
Old 01-16-2022, 05:33 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm .. how rad is protected from rocks flying in air intake path and puncturing it? how it's protected from dust or dirt getting by in air intake path and clodging rad up (probably even more of issue with rad fan sucking extra of that when it's operating)?
Old 01-17-2022, 08:20 AM   #9
grumpysnapper
I dont think it will be too much of a worry, it sits up quite high, and is shielded by the muffler.
I'm also going to put some wire mesh in front of it, to make sure.
Old 01-17-2022, 08:35 AM   #10
grumpysnapper
Passed its first proof of concept test, with flying colours.
No leaks, electrics working properly and the pump is very effective.
Lots of heat!
The 9" fan overlaps the edge of the radiator so there are some heavy plastic shrouds top and bottom to stop the fan drawing air from around the edges.
The Following User Says Thank You to grumpysnapper For This Useful Post:
soundman98 (01-17-2022)
Old 01-17-2022, 04:04 PM   #11
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Do you run a rear diffuser?
Old 01-17-2022, 07:22 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
lol that reverse light is awesome.
Have you ducted your radiator? The front one I mean.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
grumpysnapper (01-18-2022)
Old 01-17-2022, 07:28 PM   #13
Turdinator
Señor Member
Turdinator's Avatar
Where in the cooling circuit are you pulling from and returning to?
1974 TA22 Celica
2013 86 GT
Old 01-18-2022, 01:06 AM   #14
86TOYO2k17
Drives: 2017 toyota 86
This is pretty sweet setup.
You could also replace sections of the lines to/from the rear rad with something like this
CK100-8 Single 16 Inch Pass Heat Sink Super Flow Fluid Cooler.
Also if you don’t have already a radiator mister helps a lot. A lot of rally guys use this.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
FS: TRD "D oval" exhaust, OEM engine mounts, "STi" Radiator Cap cover Dave-ROR Engine, Exhaust, Bolt-Ons 1 05-18-2020 03:34 PM
FS: New H&R TC112 Rear Camber Bolts, PAC 2.5" Helper Springs customfab87 Brakes, Suspension, Chassis 0 02-08-2016 10:41 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
Something new for us, mounted up a set of 19" wheels on the FRS - NOT BAD! WheelDude.com FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 44 10-01-2013 10:42 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
