Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-10-2022, 05:27 AM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Arrow Throttle chamber
Hello,
anyone can proceed for dia size measurement of MY22 Throttle chamber?
Thanks
Trap63 is offline   Reply With Quote
Old 01-10-2022, 09:48 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Any reason you don't have it fixed free?
Old 01-10-2022, 09:59 AM   #3
Trap63
Trap63's Avatar
it's to verify if dia is larger than prevoius series avoiding to buy larger aftermarket chamber not so cheaper like OEM. Why to pay $900 for Cusco Throttle if OEM US may cost half?
Old 01-10-2022, 10:09 AM   #4
x808drifter
LMGTFY
I'll save you time, money and effort.
A larger throttle body isn't going to do anything on these cars. New version or old.
Old 01-10-2022, 10:10 AM   #5
Trap63
Trap63's Avatar
I am supercharged HKS.
Old 01-10-2022, 10:13 AM   #6
x808drifter
LMGTFY
Still make zero difference.
The throttle body is not a restriction at power levels under 800+ hp.
Old 01-10-2022, 01:00 PM   #7
PulsarBeeerz
Drives: JRSC BRZ SOLD
It is larger 70-74mm, something like that. Zero guarantee it will fit GEN1 IM as the bolt pattern may have changed. In the states I sent my OEM TB to Maxbore.com to enlarge from 65 to 68mm for ~$150. Maybe he'll do international? This is all Cusco does. It makes a noticeable difference in midrange and drive ability when NA because not everything is about peak power.. But with FI since you aren't trying to vacuum air in as it is forced, a larger TB can become more on/off switch when it comes to throttle modulation. I still have my bored out TB with a JRSC and I'd skip it tbh.
PulsarBeeerz is offline   Reply With Quote
Old 12-27-2022, 09:39 AM   #8
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Related question: What can I use instead of the $35 throttle body o-ring style gasket from Subaru?
What is its size in mm's? What is comparable?
Surely the 71mm throttle body is a standard one used on many cars as the style of gasket is everywhere for $5, but I don't know which one fits!
Subaru Part number: 16175AA570
The dimensions of the groove it fits in are: 82mm OD, 76mm ID.
In cross-section it's like an airship/fat cigar shape and that end to end dimension is around 6mm.
It's not like previous Gens where it was a flat gasket like most older Subaru's run.
Last edited by Scargod; 12-27-2022 at 04:23 PM. Reason: more added. Things explained...
Scargod is offline   Reply With Quote
Old 12-27-2022, 09:55 AM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Scargod View Post
Related question: What can I use instead of the $35 throttle body gasket from Subaru?
What is its size? What is comparable?
i was always told cereal boxes make great gaskets...
knew a few guys that would have perpetual diff leaks using the oem diff cover seals, but make one out of a cardboard cereal box, and it'd never leak again
Velox chamber plates and ride height? BRZHarley Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-01-2017 07:06 PM
Helmholtz chamber design differences? Var Engine, Exhaust, Transmission 3 07-25-2017 07:49 PM
FS- ARK mid pipe w/ Helmholz Chamber Jetbill Engine, Exhaust, Bolt-Ons 15 10-12-2015 05:05 PM
