Old 01-09-2022, 07:08 PM   #1
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
Works Kiwami 17" advice required please.
Looking for some advice regards to wheel sizes for some Works Kiwami wheels please.
I want 17" wheels so looking at running 225/45 tyres with the following size wheels.
Looking at - 17x7 ET38 or ET47 on the fronts and 17x8 ET35 on the rears as I would like a deeper dish look on the rears.
Im currently running 15mm spacers at the front so swaying more towards keeping as close to the oem offset by going with ET47 or just doing away with the spacers, but with the ET38 offset it will only give me 10mm.
Would the above setup likely cause any issues? Car is on Tein coilovers with a 15/20mm drop.
Thanks in advance
Jonboy73 is offline   Reply With Quote
Old 01-10-2022, 12:20 AM   #2
Tatsu333
Drives: 2020 BRZ Sport Tech RS
If it were me, I'd do away with the spacers and run the 17x8 ET35's front and rear. That size/offset is a perfect fitment all around with 225/45R17's (though I might be biased, since that's what I'm running )
Tatsu333 is offline   Reply With Quote
Old 01-10-2022, 12:45 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would highly recommend running a square setup all the way around, and adjust the rear spacing with spacers if needed.
even on the stock alignment, the inside rears always wear too fast for my liking. i know i'd nearly double my budget in tires if i ran oversized rears that couldn't be easily rotated.
Old 01-10-2022, 03:08 AM   #4
Jonboy73
Jonboy73's Avatar
You got any pics or a link so I can see your setup please?
Thanks for the reply.
Old 01-10-2022, 03:10 AM   #5
Jonboy73
Jonboy73's Avatar
This was exactly the reply I was looking for so thank you.
Old 01-10-2022, 06:01 PM   #6
Tatsu333
Agreed - a square setup is best because of the ability to rotate properly, AND it provides a better overall handling balance than a staggered setup.
If you click the link in my signature, it will take you to my member journal that has pics.
EDIT: Here's a direct link to the post that has the most pics of the wheels from various angles - https://www.ft86club.com/forums/show...8&postcount=27
Advice required: Spun out rod bearings. nasrath007 Engine, Exhaust, Transmission 57 10-10-2020 10:46 AM
Advice required: Spun out rod bearings. nasrath007 New England 5 06-01-2018 02:58 PM
Charging advice required s2kbobby Engine, Exhaust, Transmission 35 10-24-2016 11:59 AM
****ADvice REquired: Built/vs/Stock*** killerkid08 Forced Induction 54 06-09-2013 04:57 PM
works kiwami hub rings? derka-derka AUSTRALIA 3 01-12-2013 07:52 PM
