Old 01-08-2022, 09:52 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
ESC Throttle-switch settings
Everything is in but the batteries and interior wiring, which I plan to complete Tuesday. I saw a video somewhere recommending the first switch position be at 75% rather than the 60% the instructions I've seen say. So that would be 75 and 90-95. I think I'll aim for 90% rather than 95. I think that would give me a little room to adjust power at close to WOT.
Can any of you who have them offer some input?
Qwimby1 is offline   Reply With Quote
Old 01-10-2022, 12:12 PM   #2
WNDSRFR
Drives: FR-S,GTI
It's really not that big of a deal. It's a PITA mounting the switch to the gas petal but as long as it activates at full throttle everything will be fine. The purpose of the two stage switch is to reduce the shock to the compressor shaft. Once you get the switch mounted you can bend it to activate where you want it to. You really only want it activated at WOT.
I've only almost stalled my engine once by going full throttle at under 2,000 RPM. As long as you don't punch it under 2K you'll be fine.
Let us know what you think about it once you get it running. Looks like there are very few of us ESC owners left on the forum.
Old 01-10-2022, 12:43 PM   #3
Qwimby1
I've noticed that and wonder if they've gone out of fashion. It used to be that posts about them got a lot of response. Not much anymore.
Old 01-10-2022, 06:52 PM   #4
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I think it s more that they are out of production, rather than out of fashion. Hard to maintain a fanbase when maybe 200 of something exists, and went out of production 8 years ago.
I have the earlier version 1 stage switch, so I didn't think I could really help with your issue.
Old 01-10-2022, 07:00 PM   #5
DAEMANO
Time Traveller
I actually have two ESC kits (full without batteries), 1 fully functional kit, the other has a malfunctioned controller box, but everything else is ok. Kind of wondering what to do with them. Think I will be upgrading my 2013 FR-S to a 2022 GR86, so not really sure what to do with the ESC kits.
Old 01-11-2022, 09:09 AM   #6
Qwimby1
The one I bought stayed in the classified section for quite a while with no bids. I recall a couple years ago buyers would jump right on them. I was concerned about non-existant replacement parts, but decided to give it a shot after seeing the enthusiasm from those who were running them. I emailed Shiv about a tune last week but haven't heard back yet. Had to postpone my final install till next week anyway.
Old 01-11-2022, 12:45 PM   #7
Qwimby1
I just ran into an install problem. Maybe one of you who has these can advise.
There are two mini-plugs off the connector to the controller, one for the throttle switch and the other for the meter, but they're not labeled from PO and I don't know which goes where. I'm pretty sure they're not interchangeable, and I sure don't want to screw everything up. I see the throttle switch has a red-ring label and the meter is plain. Probably the only way to know is with a test probe but I have no idea about the circuitry on that connector.
What to do, what to do?
Old 01-11-2022, 04:37 PM   #8
Qwimby1
The install video clearly shows one plug with a red collar. Mine have no markings. The connector has a red wire at one end which I could probably test with a meter to see if I get current at one of the plugs.
Old 01-13-2022, 10:17 AM   #9
mrjj
Drives: GT86 2013
Please take some photos of your cables and I'll compare them to mine.
mrjj is offline   Reply With Quote
Old 01-13-2022, 10:28 AM   #10
Qwimby1
OK. Will do shortly. Thanks.
Old 01-13-2022, 11:02 AM   #11
Qwimby1
Pics
I don't know if these will help muchName:  IMG_20220113_103025747.jpg
[ATTACH]208857[/ATTACHName:  IMG_20220113_103119500.jpg
Old 01-13-2022, 02:40 PM   #12
Qwimby1
I guess I'm wondering if anyone knows it won't matter much if I get them wrong, or if it means total destruction.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Throttle Linearity Settings King Tut Software Tuning 35 04-05-2021 11:49 AM
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 07:06 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
