Old 01-06-2022, 08:43 PM   #1
Fred Flintstone
Drives: 2015 FR-S Asphalt, racing stripes,
Brake ?
Have a 2015 FRS recently had a frozen caliper after a brake pads exchange. Turns out it's because of a rubber bushing on the lower slide pin so I remove the bushing for now. The upper slide pins are a solid piece with no bushing, and will fit in the lower slide pin hole. Does anyone know why the bushing is used in the lower pin chamber? Can I just buy a set of upper pins for lower chamber?
Fred Flintstone is offline   Reply With Quote
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings fc3s_johnny Brakes, Suspension, Chassis 11 10-05-2020 10:26 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
