Drives: 2015 FR-S Asphalt, racing stripes,
Brake ?
Have hade two calipers freeze because of bushing on Lower slide pins swelling to a point it no longer slides smoothly in slide pin guide. Does anybody know why in the lower caliper slide pin there is a rubber bushing and the upper slide pin is solid?Can I just remove the bushing, or purchase four solid pins for the lower. For now just removed the bushing and lubricated the pin for quick fix. Just a daily driver but sometimes spirited. 2015 FRS.
#2 | |
Wheels for Brains
Have you repacked the pin grease before the seizing occurred? What kind of grease are you repacking those pins with? --It's a known issue that improper pin grease will cause swelling of the rubber and seizing. |
Drives: 17 Asphalt 86
My guess is the wrong lubricant is being used. An oil based brake lube will cause the bushing to swell and bind up the guide pin.
You need a silicone based lubricant like sil-glyde I did this year's ago by accident on another car. Grabbed the wrong bottle of lube off the shelf without looking. Noticed the brakes were acting weird, checked and had the same issue. Make sure to fully clean out the guide pin holes, pins and boots. Re-lube. |
| FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings | fc3s_johnny | Brakes, Suspension, Chassis | 11 | 10-05-2020 10:26 AM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
