Old 01-03-2022, 09:59 AM   #1
grumpysnapper
grumpysnapper's Avatar
That stupid oil filter dribble tray
Always hated the ridiculous engineering compromise of having to add an extra seal via an extra spacer if we wanted an oil cooler sandwich plate on our engine.
Bit the bullet and cut away enough of the lip so that the sandwich plate can now sit where it is supposed to.... lower, more compact and making way more sense.
grumpysnapper is offline   Reply With Quote
The Following 5 Users Say Thank You to grumpysnapper For This Useful Post:
BigTuna (01-03-2022), humfrz (01-03-2022), Ohio Enthusiast (01-03-2022), Silviacrazed (01-03-2022), VIP BRZ (01-03-2022)
Old 01-03-2022, 11:31 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Cutting into the engine block, adventurous.
The cutout is only needed to fit the hoses? The rest of the sandwich plate clears the lip?
Ohio Enthusiast is offline   Reply With Quote
Old 01-03-2022, 12:36 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Interesting. I had the supports bend/crack on my spacer at the end of the season during a retorque. Thankfully, it was replaced under warranty, but I had to remove the system in order to continue driving the car for winter until the replacement came.
This would eliminate that issue.. I'd like to see it all put back together when you have that done.
EDIT: Do you need a different length thread adapter though?
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
grumpysnapper (01-05-2022)
Old 01-03-2022, 07:40 PM   #4
Grady
Grady's Avatar
Great minds think alike! I did the same only I had a square Mishimoto plate so had to cut a little more out. If you zoom in you can see it. I agree with the adapter, spacer then filter it stood up to tall.
The Following User Says Thank You to Grady For This Useful Post:
grumpysnapper (01-04-2022)
Old 01-03-2022, 07:51 PM   #5
humfrz
Then it ain't a dribble "tray" no more.
Whoops, there went your warranty -
Grady (01-03-2022), Wally86 (01-05-2022)
Old 01-03-2022, 08:11 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
lol. *warranty.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (01-04-2022), Wally86 (01-05-2022)
Old 01-03-2022, 09:14 PM   #7
Grady
Grady's Avatar
I have not had a drivetrain warranty since 3k miles. I am at 35k now I think I will be ok.
The Following 4 Users Say Thank You to Grady For This Useful Post:
grumpysnapper (01-05-2022), humfrz (01-04-2022), soundman98 (01-03-2022), Wally86 (01-05-2022)
Old 01-04-2022, 12:32 AM   #8
humfrz
So, you blew up the OEM clutch within 3,000 miles and you replaced it with aftermarket?
Old 01-04-2022, 09:14 AM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
What warranty? we're all here to modify. lol
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
grumpysnapper (01-05-2022), soundman98 (01-04-2022)
Old 01-04-2022, 09:44 AM   #10
Grady
Grady's Avatar
No, Tuned and installed flex fuel at 3k miles. Turbo installed at 5k miles. Clutch lasted for a year after turbo install. It was when I replaced the tires the clutch did not have the holding power.
Old 01-05-2022, 07:07 AM   #11
grumpysnapper
This is how it looks fitted.
It still has a slight lip, maybe 3-4 mm, to keep its strength and also still catch some dribble.
If the sandwich and spacer use the same (1) centre bolt you will have to change it for a smaller one. They are very easy to find at parts stores, the thread is M20 1.5 and the normal (single) sandwich plate lenght (thicknesss) is fairly consistent across most Japanese cars
Old 01-05-2022, 07:15 AM   #12
grumpysnapper
Well, it still carries a little bit of dribble.
Yeah, warranty...that boat sailed on the day I bought the car new... weighed it on the way home then drove it into my garage and proceeded to (cough) improve it...
The Following 2 Users Say Thank You to grumpysnapper For This Useful Post:
humfrz (01-05-2022), soundman98 (01-05-2022)
Old 01-05-2022, 07:19 AM   #13
grumpysnapper
No its usually the complete hose mounting/thermostat etc area that fouls the lip, usually about a 1/3 of the sandwich plate.
The Following User Says Thank You to grumpysnapper For This Useful Post:
Ohio Enthusiast (01-05-2022)
Old 01-05-2022, 02:46 PM   #14
humfrz
Ahhhhh...... OK, got the picture -
FS (MD): Grimmspeed Intake, Perrin Inlet/CAI Filter, Green Air Filter s203.22b Engine, Exhaust, Bolt-Ons 1 03-08-2021 01:25 PM
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 03:46 AM
FS: OEM All Weather Trunk Tray/Cabin Filter/Covercraft UVS100 Windshield Cover SWPinATL Interior Parts (Incl. Lighting) 4 08-02-2016 05:23 PM
Stupid Question: When to change OEM intake filter? m.wood0213 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-17-2014 08:35 AM
