Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-28-2021, 01:37 PM   #1
MisterGoober
Drives: IS300, WRX, STI, Bicycle
How to drive on the Highway during Break-in?
Trying to keep the revs under 4k as much as possible during the break-in period.
I always believed that accelerating in the highest gear was a no-no (hard on the engine). The problem is if i'm doing 70-80 in 6th, I can't drop down to 5th without the rpms shooting over 4k.
Any thoughts? Short term issue as i'm going to get enough miles on the car to pass the break-in.
MisterGoober is offline   Reply With Quote
Old 12-28-2021, 01:54 PM   #2
azndavepgh
Drives: 2022 BRZ
I just did a 500 mile highway trip where I varied my speed enough to run between 2700 and 4000 RPM. Traffic wasn't heavy so I was able to slow down and speed up without annoying anyone.
azndavepgh is offline   Reply With Quote
Old 12-28-2021, 03:09 PM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Use break in oil to get the rings seated quicker and better.
Old 12-28-2021, 03:41 PM   #4
AK2112
AK2112's Avatar
Drives: 22 BRZ
Don't worry about it.
AK2112 is offline   Reply With Quote
Old 12-28-2021, 05:30 PM   #5
sds
Drives: '22 BRZ Limited 6MT
You want to be putting load on the motor. There’s nothing wrong with using 6th gear to accelerate at 3K RPM.
The whole point of breaking the motor in is to seat the rings using moderate to high cylinder pressures (progressively increasing). That’s going to be in the 3-4K RPM range with moderate to heavy throttle.
sds is offline   Reply With Quote
Old 12-28-2021, 05:42 PM   #6
TommyW
TommyW's Avatar
Don't use cruise control
Old 12-28-2021, 06:16 PM   #7
track junkie
Drives: 2022 Subaru BRZ
Never lug the engine in high gear at low speeds. This rule applies at all times.
Below what rpms is lugging in the 2.4 engine? I don’t practice the wrong techniques.
track junkie is offline   Reply With Quote
Old 12-28-2021, 06:23 PM   #8
sds
Do you feel the motor struggling? Vibrating? Failing to accelerate? That's lugging. If the motor can't pull the gear for you, you're lugging it.
Old 12-29-2021, 03:16 PM   #9
jongers
Drives: 19 86, 22 BRZ
Is the break in period in the Japanese owners manual 1000km rather than 1000m? I saw someone mention it in another discussion and found this video of a Japanese owner changing the oil after 1000km (3:24 into the video).
jongers is offline   Reply With Quote
Old 12-29-2021, 03:43 PM   #10
Fingat
Fingat's Avatar
Drives: 22 BRZ (WRB)
Yes
Fingat is offline   Reply With Quote
Old 01-02-2022, 07:36 PM   #11
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
The US manual states:
New Vehicle Break-In Driving – the First 1,000 miles (1,600 km)
I was hoping I would only have to drive 1000 km ~ 600 miles to finish the break-in period.
PhatFreshPrince is offline   Reply With Quote
Old 01-02-2022, 08:46 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
no reason you can't choose to do that. but if something breaks later, is it worth it?
Old 01-02-2022, 09:08 PM   #13
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
With peak torque at 3700, break-in will be less excruciating than the old engine. With the last one you'd have to quit winding right in the dip.
I plan a couple of trips to the coast from SW WA (plus the initial 170 mile drive home). Winding hill will be the perfect way to vary gears and RPM.
McMCOO is offline   Reply With Quote
Old 01-02-2022, 09:57 PM   #14
azndavepgh
Drives: 2022 BRZ
I never drove the first gen, but I think the 2.4 has plenty of pull up to 4000 for city driving. Even after the break-in, I'm not usually going past 5000 given the traffic around here.
Was On The Highway When... Tcoat Off-Topic Lounge [WARNING: NO POLITICS] 75 06-17-2016 08:51 AM
Final Drive Swap Break-in azynneo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 12-04-2015 02:11 PM
BRZ on the highway Champster BRZ First-Gen (2012+) — General Topics 11 06-15-2015 07:32 PM
I saw one of you on the highway..... Joakim3 Mid-Atlantic 1 07-20-2013 07:43 PM
Purchasing white FRS MT sat 3 hrs away, will 180 highway miles hurt break in? speedy racer Scion FR-S / Toyota 86 GT86 General Forum 7 08-25-2012 12:36 AM
