| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Engineer
Drives: WRB 2022 Subaru Brz
Front door card removal
Has anyone gotten a chance to remove the front door cards? I can't seem to find the service manual anywhere online. I wanted to see how to remove the front door panel inorder to install door speakers
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE |
ProCrastinationConsultant
there was a long-winded japanese video a while back, mostly about the guy's dinner that i believe also covered door card removal.
looked standard to me. hidden screw fasteners behind the door pull and door release, plastic pop clips along the back, bottom, and front edge, then lift up.
#3 | |
Engineer
2022 BRZ WRB 6MT
found the thread. the benefit of a new forum section is that it's easier to manually search through thread by thread...
https://www.ft86club.com/forums/showthread.php?t=147574 it's mostly identical to 1st gen procedure, just the door pull is now a pocket with 2 screws in the bottom(can see there's a right angle adapter bracket to make the transition), over the 1st gen which had a door handle, with hidden screws behind the plastic cover. otherwise, the door sheet metal looks nearly identical to 1st gen on the inside
| Door Panel Vinyl Removal | Jordan Silveira | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-06-2017 04:02 PM |
| Looking for a DIY Vid on Door Handle Removal. | Conman | DIY (Do-It-Yourself) Guides | 0 | 04-12-2017 12:25 AM |
| Door Card Removal | -max- | DIY (Do-It-Yourself) Guides | 60 | 07-13-2015 09:07 PM |
| Exterior Door Handle Removal | NYCsubaruBRZ | DIY (Do-It-Yourself) Guides | 1 | 11-16-2013 12:47 AM |
| Replacement door card clip? | Jeong | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 03-11-2013 03:41 PM |
