Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-15-2021, 04:48 PM   #1
Mcgiiver
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
rustproofing
It is worth spraying the underbody and steel parts with rustproofing? I live in a road salt area. Does the BRZ have underbody panels that hide the bodywork?
Mcgiiver is offline   Reply With Quote
Old 12-15-2021, 05:17 PM   #2
jvincent
jvincent's Avatar
FWIW my FRS that I am trading in is 8 years old, winter driven the entire time.
There are a couple of spots where I am starting to see some rust form but you have to look closely to find them.
I will not be rustproofing my BRZ.
Old 12-15-2021, 05:25 PM   #3
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
They come with 5 year rust warranty and some sort of rust protection. I wouldnt do the crazy underspray stuff.
SpectreRT is offline   Reply With Quote
Old 12-15-2021, 06:43 PM   #4
wizee
Drives: 2022 BRZ (Base, Red)
How do your subframes, jack points, and lower control arms look? Most cars with similar stamped steel construction that are over 2-3 years old start looking rusty down there without rust proofing spray.
wizee is offline   Reply With Quote
Old 12-15-2021, 07:09 PM   #5
jvincent
jvincent's Avatar
The jack points are probably the worst. I didn't use pucks and they got a little bit folded so there's some rust there, but nothing terrible.
On the subframe and other under car pieces the worst is probably the nuts/bolts since they aren't painted. You can see some rust spots on the painted metal pieces but nothing out of the ordinary for a winter driven car in a heavy salt environment.
Also worth noting is that the first gen FRS did not have all the underbody panels that the current ones do from the factory and in addition to being winter driven I've been fortunate enough to have commuted through probably a half doesn't significant construction zones over the life of the car.
Old 12-15-2021, 07:10 PM   #6
alphasaur
friendly
Drives: 17' 86
I spray under my cars with this when I do the fall oil change/winter wheel swap. Takes an extra 10 minutes and offers piece of mind. I've noticed less rust on subframe/bolts etc since I've been doing it.
https://www.amazon.com/Fluid-Film-11...613355&sr=8-24
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 12-15-2021, 08:12 PM   #7
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Probably I will do next year, focusing on worst parts. Concerned regarding rubber parts due to swelling.
What points normally do you protect?
Stonehorsw is offline   Reply With Quote
Old 12-15-2021, 08:37 PM   #8
Mcgiiver
I use this
CRC Heavy Duty Marine Corrosion Inhibitor
https://www.partsvu.com/77-06026-cor...SABEgLVXPD_BwE
It's great stuff not only for bodywork, but I spray all bolts, brake bleeders, flare joints, steel suspension parts, basically anything that might need disassembly on the future. It leaves a soft waxy film. It's like a foggy spray that can get into cavities. Four 10 ounce spray cans will do a BRZ or small pickup. It's very similar to a British rustproofing product called Waxoyl.
Old 12-15-2021, 11:05 PM   #9
alphasaur
friendly
Drives: 17' 86
I spray the control arms, bolts, and subframes/any steel.
Old 12-16-2021, 12:04 AM   #10
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I did a bit of surface rust correction after 4 years or so. Steel wool brush, naval jelly, primer, black paint.
-Edges of the front subframe
-Pinch welds on the frame
-Little gusset thing in the rear wheel well
Most of the underbody has plastic or fiberglass covers.
Old 12-16-2021, 01:59 AM   #11
tenderization
Drives: 88 RX-7, 2022 BRZ
Would this apply to people living in the LA/SF Bay Area? I'm not sure what counts as "coastal" enough to be problematic for rust...
tenderization is offline   Reply With Quote
Old 12-16-2021, 02:36 AM   #12
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
The 1st gen at least have pretty horrible rust proofing from the factory, it shocked me when i first had a look under my car. Im used to Renault though which are among the best in the market for rust protections, and my daily looked like new compared to the Gt86, even with twice the mileage. Used a spray on rust protection oil this winter which is my first with the 86 on all thee suspension, subframes etc to slow the process down.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
Old 12-16-2021, 09:58 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
easy.
look at your neighbors cars.
if any 10+ year old vehicle normally looks like this, it's a problem.
https://www.facebook.com/marketplace...tory_type=post
if you can go into the local mechanic shop, and the oxy/acetylene torch has cobwebs on it, then it's just, well, LOL.
Old 12-18-2021, 02:17 PM   #14
Strat_FRS
Drives: 2015 FRS for daily and track use
I spray LPS3 on underside before every winter and it keeps the cars nice and clean.
Strat_FRS is offline   Reply With Quote
Dealer Rustproofing a good idea? JBezugs CANADA 11 03-01-2017 04:00 AM
Few questions about rustproofing exposed metal Strife Cosmetic Modification (Interior/Exterior/Lighting) 7 08-10-2016 11:36 PM
[Question] How to remove stains from rustproofing i_4got Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 05-01-2013 04:59 AM
Rustproofing for Winter blackfireball5 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 28 11-12-2012 10:33 PM
