Old 12-15-2021, 03:17 PM   #1
dsc_pat
Drives: Too fast
Rear camber curve - any data available ?
Anyone have the camber curve for the rear, from OE static to deep into the travel using OE rear LCA ?
I would measure it myself, but only have access to aftermarket LCA equipped cars.
Will try to measure it on the 2nd gen at delivery, if before january work break end.
I did search...without any luck here or anywhere else. The closest I've got was on motoiq, but no real data avail.
Thanks,
dsc_pat is offline   Reply With Quote
RUCAs for camber better for toe curve? (or, why noone using trailing arms?) prj3ctm4yh3m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 08-14-2016 11:36 AM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Does toe affect camber in the rear? More camber on one side after alignment shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-30-2014 09:37 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
