Old 12-07-2021, 07:11 PM   #1
ToyBaruTurbo
Drives: 2014 Subaru BRZ Ltd
Trying to connect LED bar to OEM fog light wiring, where is it?
Might be a pointless question, but anyone have an idea where the wiring would be for the fog lights?
2014 BRZ Limited with factory fogs but the bulbs and mounts were removed by former owner. Same with DRLs, car has rallycross history.
I'm trying to connect an LED light bar to the factory switch on the stalk, thought this might be the wiring for both fogs and DRLs. But car running, all lights switched on, and connect both pairs to the bar and nothing. Ran the bar to the battery and it works so that's something at least.
These had small plugs connected to nothing so I figured it was safe to cut and try. Fuses are good too. I can't find any other wires at all down in that general area.
ToyBaruTurbo is offline   Reply With Quote
fog lamps, fog lights
Where do you connect DRL wiring harness to the fuse box? dthartzell Cosmetic Modification (Interior/Exterior/Lighting) 0 03-08-2019 01:13 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
Fog Light Wiring? 02.ACCORD.DUDE Electronics | Audio | NAV | Infotainment 5 11-26-2016 01:49 PM
Need help with OEM fog light wiring itsAlex Cosmetic Modification (Interior/Exterior/Lighting) 3 02-04-2016 12:10 PM
FS FRS Reverse Light Wiring FRSPhil Exterior Parts (Aero, Lighting, Etc.) 0 03-13-2015 01:11 AM
