Old 12-03-2021, 03:36 PM   #1
DoubleAKash
Drives: 2019 Subaru BRZ - JDL Turbo Kit
Exhaust Recommendation on JDL Turbo Setup
Hey ya'll I've finally gotten the JDL Turbo Kit installed and it sounds awesome and pulls amazingly on the GTX2867R Gen2 setup. However, I'm curious to know what exhaust y'all are running on your cars.
Currently I'm on the 2.5" Resonated Perrin catback and 2.5" JDL dual resonated front pipe and its much much quieter thank I thought (~80 db at redline outside standing a few feet away). My turbo setup outlet flange was set to 2.5". Would it be worth upgrading to a 3" catback or if I want something slight louder to just go for another 2.5" catback?
DoubleAKash is offline   Reply With Quote
Old 12-03-2021, 04:03 PM   #2
Ashikabi
Ashikabi's Avatar
I don't know that 3 inch will make it louder but it should have a deeper tone. I think muffler style will have a much greater affect on volume. "Tuner" style cans will be loud and suitcases will be quiet
Old 12-03-2021, 06:41 PM   #3
Grady
Grady's Avatar
Upgrading the cat back to 3 inch will do nothing. Change sound possibly. Upgrade to full 3 inch exhaust will get loud and better spool.
Old 12-03-2021, 11:32 PM   #4
jflogerzi
jflogerzi's Avatar
as others said 2.5inch is not really an issue till 400+WHP so 3inch would be more noise and NVH from drone. You want more noise switch out cat back. You already have a ball bearing turbo in the GTX line so you won't gain much more spool time. What boost and fuel are you running?
Look at something like this if you have access to a stock Midpipe
https://shop.namelessperformance.com...-pipe-brz-frs/
2013 Series 10 FRS #553
Old 12-05-2021, 07:17 PM   #5
DoubleAKash
so i'm on 8.5 psi I believe (that is what is on the dyno sheet) on 91 octane
I was thinking about going with something like the corsa or the MXP RS. I've had the Invidia N2 but the drone was too much for me, however that was also before I had a dual resonated front pipe
Old 12-05-2021, 07:19 PM   #6
jflogerzi
jflogerzi's Avatar
Of those 2 Corsa for sure. Turbo will help with dual resonated FP
Sent from my Pixel 5a using Tapatalk
Exhaust Recommendation Dennett_ Engine, Exhaust, Transmission 21 03-08-2017 04:59 PM
Recommendation for track lapping day setup WWFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 02-03-2017 11:58 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
FA20 turbo exhaust setup. Baramzisyan Engine, Exhaust, Transmission 26 02-20-2014 07:58 AM
